Termostat s LCD Nokia 3310 a DS18B20
Karya
#16 Příspěvek od Karya »
Tak skusal som dalsiu schemu prekreslit.Pomozte kde zase mam chybu.Prevziate z fora http://www.picbasic.co.uk/forum/showthread.php?t=327
sobory pre Isis7. http://www.ulozto.cz/xbnYM3h/nokia-3310-7z
Obrázek
Kód: Vybrat vše
'      Thermometer 2 Zone &   Thermostat
'          with Nokia 3310 display
'       DEVICE 16F628A AND DS18B20 x 2
'                   ver.2.1
'        Thanks to all members from  :
'       http://www.picbasic.co.uk/forum
'  by Niculescu Dan : niculescu_dann@yahoo.com
'@ DEVICE pic16F628A, INTosc_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF     ' for PBP 2.4
@ DEVICE pic16F628A, INTRC_osc, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_OFF, LVP_OFF, CPD_OFF, PROTECT_OFF       ' for PBP 2.5
Define  NO_CLRWDT 1
DEFINE  OSC 4
        TRISB = %00001110        'portB configuration  0=out 1=in
        TRISA = %10100010        'portA configuration
        PortA = %11100010
        CMCON = 7                'for P16F628
        VRCON = 0                'for P16F628
        INTCON = 0
        OPTION_REG = %10000111
RST         var  PortA.4   'pin 3   Output   reset display
SDIN        var  PortA.3   'pin 2   Output   master data out
SCK         var  PortA.2   'pin 1   Output   Spi clock
DQ          var  PortA.1   'pin 18  I/O      DQ DS18b20
D_C         var  PortB.0   'pin 6   Output   command/data sel. register
            temperature     var  Word
            TempC           var  byte
            Float           var  byte
            temperature2    Var  Word
            Dummy           var  byte
            TempC2          var  byte
            Float2          var  byte
            Bitovi          var  byte
            Bitovi2         var  byte
            Predznak        var  Bitovi.0
            Predznak2       var  Bitovi2.0
            Minus           var  Byte
            LcdReg          var  byte
            x               var  byte
            y               var  byte
            Offset          var  byte
            Char            var  byte
            a               var  byte
            PosX            VAR  Byte
            PosY            VAR  Byte
            Chr             VAR  Byte
            LcdData         VAR  Byte
      TargetTemp       Var   Word      ' Desired Temperature
            Hyst          Var   Word      ' Hystereris
            V          Var   Word      ' Var. for display
            V2          Var   Word      ' Var. for display
            B1              Var  Byte   ' Byte for TargetTemp calculation
            B2              Var  Byte   ' Byte for TargetTemp calculation
            Mode           Var  Byte   ' 0=Temp. display, 1=Set Temp, 2=Set Hysteresis
            Sign            Var  Byte
            Sign2           Var  Byte
DS18B20_1_12bit    CON %01111111 ; 750ms,   0.0625°C
DS18B20_2_12bit    CON %01111111 ; 750ms,   0.0625°C
DATA 46, 224, 10                        ' Temp MSB, TEMP LSB, Hysteresis DIV 10
PORTb.6=0                               ' Warm Output Low
PORTb.7=0                               ' Cold Output Low
Mode=0                                  ' Temperature display mode
Read 0, B1                              ' Read TargetTemp MSB
Read 1, B2                              ' Read TargetTemp LSB
TargetTemp=B1*256+B2                    ' Calculate TargetTemp value (Default=20.0 C.)
Read 2, B1                              ' Read Hysteresis
Hyst=10*B1                               ' Calculate Hysteresis value (Default= 2.0 C.)
                   DATA @10,$3E,$51,$49,$45,$3E,_       ';// 0    2
                            $00,$42,$7F,$40,$00,_       ';// 1    3
                            $42,$61,$51,$49,$46,_       ';// 2    4
                            $21,$41,$45,$4B,$31,_       ';// 3    5
                            $18,$14,$12,$7F,$10,_       ';// 4    6
                            $27,$45,$45,$45,$39,_       ';// 5    7
                            $3C,$4A,$49,$49,$30,_       ';// 6    8
                            $01,$71,$09,$05,$03,_       ';// 7    9
                            $36,$49,$49,$49,$36,_       ';// 8    10
                            $06,$49,$49,$29,$1E,_       ';// 9    11
                            $08,$08,$3E,$08,$08,_       ';// +    12
                            $08,$08,$08,$08,$08,_       ';// -    13
                            $00,$60,$60,$00,$00,_       ';// .    14
                            $01,$01,$7F,$01,$01,_       ' T       15
                            $7F,$49,$49,$49,$41,_       ' E       16
                            $7F,$02,$0C,$02,$7F,_       ' M       17
                            $7F,$09,$09,$09,$06,_       ' P       18
                            $00,$41,$7F,$41,$00,_       ' I       19
                            $7F,$04,$08,$10,$7F,_       ' N       20
                            $63,$14,$08,$14,$63,_       ' X       21
                            $03,$04,$78,$04,$03,_       ' Y       22
                            $26,$49,$49,$49,$32,_       ' S       23
                            $7F,$08,$08,$08,$7F         ' H       24
                pause 100
                RST = 1
                PortB = 0
                LcdReg  =  %00100001          'LCD Extended Commands.
                call    PrintCtrlLcd
                LcdReg  =  $C8                'Set LCD Vop (Contrast).    initial a fost $c5
                call    PrintCtrlLcd
                LcdReg  =  %00000110          'Set Temp coefficent.
                call    PrintCtrlLcd
                LcdReg  =  %00010011          'LCD bias mode 1:48.
                call    PrintCtrlLcd
                LcdReg  =  %00100000          'LCD Standard Commands, Horizontal addressing mode.
                call    PrintCtrlLcd
                LcdReg  =  $0C                'LCD in normal mode.  $0D inverse
Call    PrintCtrlLcd
Call CursorHome
Gosub LCD_Clear
' Init Sensor 1
 OWOut DQ, 1, [$55, $28,  $DD, $06, $49, $1, $0, $0, $D4, $4E, $FF, $FF, $7F]
 OWOut DQ, 1, [$55, $28,  $DD, $06, $49, $1, $0, $0, $D4, $48]
 OWOut DQ, 1, [$55, $28,  $DD, $06, $49, $1, $0, $0, $D4, $B8]
 OWOut DQ, 1, [$55, $28,  $DD, $06, $49, $1, $0, $0, $D4, $BE]
Pause 50
 OWIn DQ, 2, [temperature.byte0, temperature.byte1]
Pause 50
' Init Sensor 2
 OWOut DQ, 1, [$55, $28,  $EB, $EA, $48, $1, $0, $0, $FF, $4E, $FF, $FF, $7F]
 OWOut DQ, 1, [$55, $28,  $EB, $EA, $48, $1, $0, $0, $FF, $48]
 OWOut DQ, 1, [$55, $28,  $EB, $EA, $48, $1, $0, $0, $FF, $B8]
 OWOut DQ, 1, [$55, $28,  $EB, $EA, $48, $1, $0, $0, $FF, $BE]
Pause 50
 OWIn DQ, 2, [temperature2.byte0, temperature2.byte1]
Pause 50
MainLoop:
If PORTB.3=0 then
Pause 50
Gosub LCD_Clear
Call Apel
  If PORTB.3=0 then MainLoop            ' Wait until button is released
  Mode=Mode+1                           ' Increment mode
  If Mode=2 then                        ' Save Target Temperature (Mode1 -> Mode2)
   Write 0, TargetTemp / 256          ' TargetTemp MSB
   Write 1, TargetTemp MOD 256          ' TargetTemp LSB
  EndIf
  If Mode > 2 Then                      ' Save Hysteresis (Mode 2 -> Mode 0)
   Mode=0                         ' Only 0, 1, 2 are valid
   Write 2, Hyst / 10                   ' Divide Hyst value to fit in Byte
  EndIf
Endif
 If Mode =1 then
                LcdReg  =  %10000000 + 12        ' cursor  X
                call    PrintCtrlLcd
                LcdReg  =  %01000010             ' cursor  Y
                call    PrintCtrlLcd
                Char = 15
                call    PrintChar
          Char = 16
                call    PrintChar
                Char = 17
                call    PrintChar
          Char = 18
                call    PrintChar
  V=TargetTemp                          ' TargetTemp in V
  Gosub SelectSign                      ' Select +/blank/-
  Gosub DTemp                           ' Display Target Temperature
  If (PORTB.1=0) Or (PORTB.2=0) then   ' Up or Down button pushed
   If PORTB.2=0 then                   ' Down button
    If TargetTemp > 7500 then          ' Not lower than -25 C. (10000-MinTemp * 100)
     TargetTemp=TargetTemp-10           ' Decrease temperature with 0.25 C.
    EndIf
   EndIf
   If PORTB.1=0 then                   ' Up button
    If TargetTemp < 17500 then         ' Not higher than 75 C. (10000+MaxTemp * 100)
     TargetTemp=TargetTemp+10           ' Increase temperature with 0.25 C.
    EndIf
   EndIf
   GoSub SetTargetTemp                  ' Display TargetTemp and delay 0.25 Sec.
  EndIf
 EndIf
 If Mode=2 then                         ' Set Hysteresis
                call    PrintCtrlLcd
                LcdReg  =  %01000011            ' cursor  Y
                call    PrintCtrlLcd
                Char = 24
                call    PrintChar
                Char = 22
                call    PrintChar
                Char = 23
                call    PrintChar
                Char = 15
                call    PrintChar
  Sign=" "                              ' No sign
  V= 10000+Hyst                         ' Set value for V
  Gosub DTemp                           ' Display Hysteresis
  If (PORTB.1=0) Or (PORTB.2=0) then    ' Up or down button pushed
   Sign=" "                             ' No sign for Hysteresis
   If PORTB.1=0 then                    ' Down button
    If Hyst > 10 then Hyst=Hyst-10      ' Not less than 0.1 C.
   EndIf
   If PORTB.2=0 then                    ' Up button
    If Hyst < 1000 then Hyst=Hyst+10    ' Not more than 10.0 C.
   EndIf
   Pause 250                            ' Delay 0.25 Sec.
  EndIf
 EndIf
 If Mode > 0 then Mainloop         ' Setting TargetTemperature or Hysteresis
Output DQ                      ' Make Pin Output
 DQ=0                     ' OneWire line Low
 PauseUs 480                        ' Keep down for 480 µS
 Input DQ                           ' Make Pin Input
 PauseUs 70                         ' Wait 70 µS
 If DQ=1 then                       ' No presence pulse from DS1820
 Pause 500                          ' Wait 0.5 Sec.
 Goto MainLoop                      ' Check again
EndIf
Main:
Call BorderLine
Part1:
' Start temp.conv.Sensor1
 OWOut DQ, 1, [$55, $28,  $DD, $06, $49, $1, $0, $0, $D4, $44]
 WaitLoop:
 While not DQ
 Wend
 Pause 500
                Predznak = 0
                if  temperature.15 then
                    temperature  = ~ temperature + 1
                    Predznak = 1
                endif
Dummy = 625 * Temperature
TempC = DIV32 10
TempC = (Temperature & $7FF) >> 4
Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
Temperature=TempC*100 + Float
 If Predznak then
  V= 10000 - Temperature               ' 25 C=12500  0 C=10000  -10 C=9000
  Predznak = 0
 else
  V= 10000 + Temperature
 EndIf
 If V >= 10000 then                     ' Above 0 C.
  Temperature=V-10000
 Else
  Temperature=10000-V                  ' Below 0 C.
 EndIf
  If V < TargetTemp - Hyst then          ' Below Target temperature - Hysteresis
  PORTB.6=1                             ' Activate   Warm Output
  PORTB.7=0                             ' Deactivate Cold Output
 EndIf
 If V > TargetTemp + Hyst then          ' Above Target temperature + Hysteresis
  PORTB.6=0                             ' Deactivate Warm output
  PORTB.7=1                             ' Activate   Cold Output
 EndIf
 GoSub SelectSign                       ' +/blank/- Sign
  Temperature=V-10000
 Else
 EndIf
'---------------setting cursor for text "TEMP.INT :"
                LcdReg  =  %10000000            ' cursor  X
                call    PrintCtrlLcd
                LcdReg  =  %01000001            ' cursor  Y
                call    PrintCtrlLcd
                Char = 15
                call    PrintChar
                Char = 16
                call    PrintChar
                Char = 17
                call    PrintChar
                Char = 18
                call    PrintChar
                Char = 14
                call    PrintChar
                Char = 19
                call    PrintChar
                Char = 20
                call    PrintChar
                Char = 15
                call    PrintChar
'---------------setting cursor for display the temperature 1
                LcdReg  =  %10100000 + 22       ' cursor  X
                call    PrintCtrlLcd
                call    PrintCtrlLcd
'---------------now display temperature 1
                    if TempC > 99 then
                        Char = 3
                        call    PrintChar
                    endif
                    If sign ="-"   then
                        Char = 13
                        call PrintChar
                        else
                        Char = 12
                        call    PrintChar
                    endif
                Char = (temperature dig 3) + 2
                call    PrintChar
                Char = (temperature dig 2) + 2
                call    PrintChar
                Char = 14
                call    PrintChar
                Char = (temperature dig 1) + 2
                Call    PrintChar
'                Char = (temperature dig 0) + 2
'                Call    PrintChar
Part2 :
' Start temp. conv.Sensor2
OWOut DQ, 1, [$55, $28, $EB, $EA, $48, $1, $0, $0, $FF, $44]
WaitLoop2:
While not DQ
Wend
Pause 500
OWIn DQ, 2, [Temperature2.Byte0, Temperature2.Byte1]
                Predznak2 = 0
                if  temperature2.15 then
                    temperature2  = ~ temperature2 + 1
                    Predznak2 = 1
                endif
Dummy = 625 * Temperature2
TempC2 = DIV32 10
TempC2 = (Temperature2 & $7FF) >> 4
Float2 = ((Temperature2.Lowbyte & $0F ) * 25 )>>2
Temperature2=TempC2*100 + Float2
 If Predznak2 then
  V2= 10000 - Temperature2
  Predznak2 = 0
 else
  V2= 10000 + Temperature2
 EndIf
 If V2 >= 10000 then                     ' Above 0 C.
  Temperature2=V2-10000
 Else
  Temperature2=10000-V2                  ' Below 0 C.
 Endif
 GoSub SelectSign
 Else
 EndIf
'---------------setting cursor for text "TEMP.EXT :"
                call    PrintCtrlLcd
                call    PrintCtrlLcd
                Char = 15
                call    PrintChar
                Char = 16
                call    PrintChar
                Char = 17
                call    PrintChar
                Char = 18
                call    PrintChar
                Char = 14
                call    PrintChar
                Char = 16
                call    PrintChar
                Char = 21
                call    PrintChar
                Char = 15
                call    PrintChar
'---------------setting cursor for display the temperature 2
                call    PrintCtrlLcd
                LcdReg  =  %01000100            ' cursor  Y
                call    PrintCtrlLcd
'---------------now display temperature 2
                    if TempC2 > 99 then
                        Char = 3
                        call    PrintChar
                    endif
                    If sign2 ="-"   THEN
                        Char = 13
                        call PrintChar
                        else
                        Char = 12
                        call    PrintChar
                    endif
                Char = (temperature2 dig 3) + 2
                call    PrintChar
                Char = (temperature2 dig 2) + 2
                call    PrintChar
                Char = 14
                call    PrintChar
                Char = (temperature2 dig 1) + 2
                Call    PrintChar
'                Char = (temperature2 dig 0) + 2
'                Call    PrintChar
'--------------- display target
                call    PrintCtrlLcd
                LcdReg  =  %01000101            ' cursor  Y
                call    PrintCtrlLcd
                Char = 23
                call    PrintChar
                Char = 16
                call    PrintChar
                Char = 15
                call    PrintChar
                LcdReg  =  %10000000  + 24      ' cursor  X
                call    PrintCtrlLcd
                call    PrintCtrlLcd
                Char = (TargetTemp dig 3) + 2
                call    PrintChar
                Char = (TargetTemp dig 2) + 2
                call    PrintChar
                Char = 14
                call    PrintChar
                Char = (TargetTemp DIG 1) + 2
                Call    PrintChar
goto MainLoop
CursorHome:     LcdReg  =  %10000000            ' cursor Home
                call    PrintCtrlLcd
                LcdReg  =  %01000000            ' cursor Home
                call    PrintCtrlLcd
                return
PrintChar:   offset = Char * 5
                for a = 1 to 5
                    read offset, LcdReg
                    call  PrintDataLcd
                    offset = offset + 1
                next a
                LcdReg = 0
                call    PrintDataLcd
                return
PrintCtrlLcd:   D_C = 0
PrintDataLcd:   for x = 1 to 8
                    SDIN = LcdReg.7
                    SCK = 1
                    LcdReg = LcdReg << 1
                    SCK = 0
                next x
                D_C = 1
                return
LCD_Clear:
  PosX=0:PosY=0:GOSUB LCD_GotoXY
  HIGH D_C
  FOR Chr=1 TO 252
      LcdData=0:GOSUB LCD_ByteOut
  NEXT Chr
RETURN
LCD_GotoXY:
  LOW D_C
  LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
  LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
RETURN
LCD_ByteOut:
  SHIFTOUT SDIN,SCK,1,[LcdData]
RETURN
SetTargetTemp:
 V=TargetTemp
 Gosub SelectSign
 Gosub DTemp
 Pause 250
Return
DTemp :
  Temperature=V-10000
 Else
 EndIf
                LcdReg  =  %10100000 + 14       ' cursor  X
                call    PrintCtrlLcd
                call    PrintCtrlLcd
                call    PrintChar
                call    PrintChar
                Char = 14
                call    PrintChar
                Call    PrintChar
Return
SelectSign:
 If v = 10000 then         ' Temperature = 0 C.
  Sign=" "                       ' No sign
 Else
  If v < 10000 then                     ' <> 0
   Sign="-"                      ' Temperature below 0 C.
  Else
   Sign="+"                      ' Temperature above 0 C.
  EndIf
 EndIf
 If v2 = 10000 then        ' Temperature = 0 C.
  Sign2=" "                       ' No sign
 Else
  If v2 < 10000 then                     ' <> 0
   Sign2="-"                      ' Temperature below 0 C.
  Else
   Sign2="+"                      ' Temperature above 0 C.
  EndIf
 EndIf
Return
BorderLine:
'=================================== UP
               call    PrintCtrlLcd
                LcdReg  =  %01000000            ' cursor  Y
               call    PrintCtrlLcd
                 for y = 0 to 73
      LOokup y, [$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3F,$3F,$21,$21,$3F,$1E,$00,$3F,$3F,$00,_
               $1E,$3F,$21,$29,$3B,$1A,$00,$3F,$3F,$00,_
                 $01,$01,$3F,$3F,$01,$01,$00,$3E,$3F,$09,$09,$3F,$3E,$00,_
                 $3F,$3F,$20,$20,$20,_
                 $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
               $18,$27,$27,$18,$00,$00,$00,$00,$06,$06,_
               $00,$1E,$3F,$21,$21] ,LcdReg
'                 for y = 0 to 83
'      LOokup y, [$01,$01,$01,$01,$01,$01,$01,$01,_
'                 $01,$01,$01,$01,$01,$01,$7F,$7F,$43,$43,$7F,$3D,$01,$7F,$7F,$01,_            'DI
'                 $3D,$7F,$43,$53,$77,$35,$01,$7F,$7F,$01,$03,$03,$7F,$7F,$03,$03,$01,_        'GIT
'                 $7D,$7F,$13,$13,$7F,$7D,$01,$7F,$7F,$41,$41,$41,$01,$01,$01,$01,$01,_        'AL
'                  $01,$01,$01,$31,$4F,$4F,$31,$01,$01,$01,$0D,$0D,$01,$3D,$7F,$43,$43,$43,_
'                $01,$01,$01,$01,$01,$01,$01,01] ,LcdReg
                   call    PrintDataLcd
                   next y
'===================================  DOWN
'          LcdReg  =  %10000000            ' cursor  X
'               call    PrintCtrlLcd
'                LcdReg  =  %01000101            ' cursor  Y
'               call    PrintCtrlLcd
'                 for y = 0 to 83
'      LOokup y, [$80,$80,$80,$80,$80,$80,$FE,$CA,$CA,$B4,$80,$8E,$D0,$D0,$BE,_          'BY
'                $80,$80,$80,$80,$FE,$88,$90,$FE,$80,$FE,$80,$BC,$C2,$C2,$A4,_          'NIC
'                 $80,$BE,$C0,$C0,$BE,$80,$FE,$C0,$C0,$C0,$80,$FE,$CA,$CA,$C2,_          'ULE
'                 $80,$A4,$CA,$CA,$B0,$80,$BC,$C2,$C2,$A4,$80,$BE,$C0,$C0,$BE,_          'SCU
'                $80,$80,$80,$80,$FE,$C2,$C2,$BC,$80,$FC,$92,$92,$FC,$80,$FE,_          'DAN
'                $88,$90,$FE,$80,$80,$80,$80,$80,$80] ,LcdReg
'                   call    PrintDataLcd
'                    next y
       return
 '=================================== end of BorderLine
Apel:
               call    PrintCtrlLcd
               call    PrintCtrlLcd
                Char = 23
                call    PrintChar
                Char = 16
                call    PrintChar
                Char = 15
                call    PrintChar
Return
End        'of program
Karya
#17 Příspěvek od Karya »
Uz som nato dosiel.Vo vlastnostach procesora som nemal nastavene 4mhz ale len 1mhz.Preto to neslo
Charlie88
#18 Příspěvek od Charlie88 »
Ahoj lidi, s PIC teprve začínám tak pokud bude moje otázka blbá tak sorry. Chci postavit známý teploměr s LCD z Nokie ( http://www.radiolocman.com/shem/schemat ... l?di=44132 ). HEX se dá stáhnout všude ale mě jde o tu grafiku. Je přímo v tom HEX? Píše se už v ASM nebo až pak v nějakém programu? Pomozte prosím díky ;-)
Karya
#19 Příspěvek od Karya »
Vsetko je v hex
