textový string v XC8
Ladin
#31 Příspěvek od Ladin »
No mě to bez const nepřeloží, vypíše hlášku, že má málo paměti, jakmile dám const tak se tam vejde i dvakrát tolik...
Originál kod od microchip ke kitu co jsem kupoval je tento:
Kód: Vybrat vše
 * Lesson 12 - "LookupTable"
 * This shows using a table lookup function to implement a
 * binary to gray code conversion.  The POT is read by the A2D,
 * The high order 4 bits then are converted to Gray Code and
 * displayed on the LEDs.
 * The ADC value is used as the offset into reading the gray code equivalent inside of
 * a constant data array.
 * Gray coded binary will be reflected on the LEDs in accordance with the POT reading
 * PIC: 18F14K22
 * Compiler: XC8 v1.00
 * IDE: MPLABX v1.10
 * Board: PICkit 3 Low Pin Count Demo Board
 * Date: 6.1.2012
 * See Low Pin Count Demo Board User's Guide for Lesson Information*
#include <htc.h>                         //PIC hardware mapping
#define _XTAL_FREQ 500000                //Used by the compiler for the delay_ms(x) macro
//config bits that are part-specific for the PIC18F14K22
__CONFIG(1, FOSC_IRC & PLLEN_OFF & FCMEN_OFF);
__CONFIG(2, PWRTEN_OFF & BOREN_OFF & WDTEN_OFF);
__CONFIG(3, HFOFST_OFF & MCLRE_OFF);
__CONFIG(4, STVREN_ON & LVP_OFF & DEBUG_ON);
__CONFIG(5, CP0_OFF & CP1_OFF & CPB_OFF & CPD_OFF);
__CONFIG(6, WRT0_OFF & WRT1_OFF & WRTC_OFF & WRTB_OFF & WRTD_OFF);
__CONFIG(7, EBTR0_OFF & EBTR1_OFF & EBTRB_OFF);
unsigned char adc(void); //prototype
                     //Important to use the 'const' keyword here. This puts the array
                     //into program space instead of data space. This is ideal for values
                     //that do not change
                     //  b'0000'       :  0
                     //  b'0001'       :  1
const unsigned char gray_code[] = {     //lookup table for binary->gray code
    0b0000,0b0001,0b0011,0b0010,0b0110,
    0b0111,0b0101,0b0100,0b1100,0b1101,
    0b1111,0b1110,0b1010,0b1011,0b1001,
    0b1000
void main(void){
    unsigned char adc_value;
    OSCCON = 0b00100010;                //500KHz clock speed
    TRISC = 0;                          //all LED pins are outputs
    TRISAbits.TRISA4 = 1;                //Potentiamtor is connected to RA4...set as input
    ANSELbits.ANS3 = 1;                  //analog input - different than pic16 syntax
    ADCON0 = 0b00001101;                 //select RA4 as source of ADC, which is AN3, and enable the module
    ADCON2 = 0b00000001;                 //left justified - FOSC/8 speed
    while(1){
       adc_value =  adc();              //get the ADC value from the POT
       adc_value >>= 4;                 //save only the top 4 MSbs
       LATC = gray_code[adc_value];     //convert to Grey Code and display on the LEDs
unsigned char adc(void) {
    __delay_us(5);                      //wait for ADC charging cap to settle
    GO = 1;
    while (GO) continue;                //wait for conversion to be finished
    return ADRESH;                      //grab the top 8 MSbs
a je tam uvedeno:
Important to use the 'const' keyword here. This puts the array into program space instead of data space. This is ideal for values that do not change.
Tak co myslíte? Je možné, že u atmelu je to jinak než u picu? Bylo by to jednodužší... 8-)
Aha tak možná to umístění bude důležité...
Jeejda_teda_puvodne
#32 Příspěvek od Jeejda_teda_puvodne »
Naposledy upravil(a) Jeejda_teda_puvodne dne 25 říj 2016, 19:44, celkem upraveno 1 x.
Ladin
#33 Příspěvek od Ladin »
Budu věřit manuálu a svejm očím, původní kód upravuju kdyby to někdo chtěl použít... Díky
