VIDEO PHILIPS
Napsal: 29 pro 2006, 16:54
od KUBO
VIDEO PHILIPS VR 742 SA PRI PREHRAVANI ZASTAVILO A VYPLO. PO ROZOBRATI KRYTU A PRIPOJENIM NA SIET SA SPUSTILO.HLAVA SA KRUTILA KROKOVO RAZ DO LAVA RAZ DO PRAVA A POTOM TO VYPISALO NA DISPEJI CISLO 4. TAK SOM POCKAL CHVILU A ESTE RAZ SOM HO PRIPOJIL NA SIET ABY SOM VYBRAL KAZETU CO SA MI AJ PODARILO A PO CHVILI VYPISALO CISLO 3. TERAZ SA DA ZAPNUT POWER TLACITKOM ALE DISPLEJ SVIETI ASI SEKUNDU A CELKOM SA VYPNE. NA VLOZENIE KAZETY NEREAGUJE. PROSIM VAS NEMA NIEKTO CHYBOVE KODY K TOMU PHILIPSU A KDE BY SA DALA ZOHNAT SCHEMA. DAKUJEM :cry:
re:
Napsal: 29 pro 2006, 18:59
od durkovic
Vycistit modeswitch a ked nepomoze tak vymenit elyty v zdroji.Inak neviem... :?
