P: Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H
Napsal: 03 bře 2024, 11:41
Prodám Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H.
Cena: 700 cz
Možnost osobného predania Praha - Letňany.
Popis EN:
Arc Magnet OR18xIR14x45deg.x20 mm Diameter 36mm N42H Strong Motor Magnet for Generators Wind Turbine Neodymium NdFeB
Specifications(1"=25.4mm; 1lbs=0.453kg)
Dimensions: OR18.00*IR14.00*45Deg.*20.00mm (+/-0.1mm) (Outer Radius*Inner Radius*Angel*Height)
Material: Neodymium (NdFeB)
Grade: N42H
Maximum Temperature: 120 Degree Celsius (248 deg F)
Coating: Nickel (NiCuNi)
Magnetization: Inside Curve to Outside Curve
1 lot = 4pcs N Pole Outside + 4pcs S Pole Outsid
Cena: 700 cz
Popis EN:
Grade: N42H
