Hlava Canon BC-10 (BJC-30/35/50/55/80/85)
Napsal: 08 črc 2025, 08:51
Nemate niekto ciernu hlavu Canon BC-10 (do prenosnych tlaciarni BJC-30/35/50/55/80/85)? Potreboval by som premerat a porovnat s mojou.
Tlaciaren ukazuje chybu cartridgu a neviem, ci mam zhanat novu. Nie su velmi dostupne.
Napsal: 08 črc 2025, 22:44
Pozeram servisny manual - na detekciu hlavy sa vraj pouzivaju signaly ID0, ID1 a HCONT. Tie su vporiadku (0, 0, 1) - namerane na konektore na doske. Ak to inu detekciu to nerobi, tak je chyba na doske.
Napsal: 12 črc 2025, 23:22
Nenameral som ziadnu diodu medzi pinmi DIA a DIK. Ale to by malo hodit inu chybu - head temperature error. Este som nenameral nic na pine 3, ostatne vyzeraju byt OK (18 a 27 su zapojene len na farebnej hlave).
Po zapnuti to 3-krat zapipa (pritom svietia LED POWER aj ERROR) = "BJ cartridge check" a vystrci hlavu do stredu - na vymenu. Pri stlaceni CARTRIDGE len pipne, hlava sa nevrati.
Poliaci mali rovnaky problem, nevyriesili:
https://www.elektroda.pl/rtvforum/topic1304564.html
Napsal: 14 črc 2025, 23:41
Skusil som pridat externu diodu medzi DIA a DIK. Potom to hadzalo okrem povodnej chyby (3 pipnutia) este aj chybu "Abnormal temperature rise" (8 pipnuti a obe LED blikaju)
servisny manual píše:BJ cartridge Detection with head rank and head temperature sensor
Na pine RANK (TOP) je s cartridgom asi 0,59V, bez neho 0,61V. Skusil som to stiahnut dolu a detekcia presla!
Napsal: 15 črc 2025, 20:33
Stiahnutie k nule znamena, ze je nasadena skenovacia hlava IS-12.
Rank je odpor zapojeny druhym koncom na zem. V mojom pripade 1K024.
BJC-2000 service manual píše:Rank resistor
To execute optimum heat control of each BJ cartridge, production-related deviation
in heater characteristics is classified into 13 types which are identified by changing
the rank resistance. From the MPU & Printer Controller's analog port, the MPU
detects the different rank resistances as voltage values and converts them from
analog to digital for detection. The heater's characteristics are thereby recognized.
BJC-2000 service manual píše:This printer detects the presence of a BJ cartridge by the two resistance values of
TOP (pin 9) and DIODEA (pin 10) of the cartridge signal contacts. When the
resistance value of TOP is 750 or less and that of DIODEA is not zero , the printer
decides that the cartridge is installed.
V servisnom manuli BJC-2000 je aj pekna schema hlavy BC-20, ktora je asi podobna. Je tam okrem rank odporu vidiet aj dve diody v serii na meranie teploty (preto som ju nenameral).
Otazne je, preco nefunguje ta detekcia rank. Odpor R49 (1K) a rank odpor tvoria delic, signal HRANK ide do analogoveho multiplexera a analogoveho vstupu procesora. To by bolo ale prilis jednoduche. Je tam odbocka TOPCC, cez ktoru sa to uzemni cez IC15 (UPA2003GR) 8O Ovladaci signal TOPC vychadza z procesora a je stale aktivny...
Napsal: 16 črc 2025, 21:30
Odpojil som pin 2 z IC15. Napatie na HRANK vyliezlo na 2,55V. Detekcia stale nefungovala.
Zapojil som dve seriove diody medzi DIA a DIK. Detekcia stale nefungovala.
Pripojil som na HRANK odpor 470R na zem. Detekcia konecne funguje!
Da sa spustit aj tlac, akurat je to asi zaschnute a prazdne.
Napsal: 17 črc 2025, 11:12
od Mahoney
Destilovaná voda a ultrazvuk, akorát když je to zaschnuté moc a dlouho a dlouho se s tím třepe, tak se někdy poškodí/odlepí trysky a pak je po hlavě.
Napsal: 17 črc 2025, 11:29
Kedysi som uspesne vycistil tuto hlavu v BJC-85 vodou a injekcnou striekackou (bez ihly). Bola uplne upchata - nevytlacila nic, len sa po chvili prehriala.
Skusim to aplikovat aj tu - ale je mozne, ze je mrtva.
Napsal: 17 črc 2025, 20:16
Pripojil som naspat signal TOPC na pin 2 IC15, detekcia stale funguje.
Jeho vyznam som nepochopil, ale osciloskop aspon ukazal funkciu. Procesor tento signal s frekvenciou 10Hz vzdy na ~290us deaktivuje a zjavne vtedy meria napatie.
Zaujimave je, ze to trva aj po vypnuti tlaciarne, aj ked je napajana len z baterie. "Ticho" je len po vybrati a vlozeni baterie, do prveho zapnutia.
Napsal: 05 led 2026, 21:11
Kupil som "novu" nerozbalenu hlavu BC-10. Detekcia funguje (tlaciaren som vratil do povodneho stavu) a tlaci!
