Chlazeni LED
Napsal: 29 pro 2011, 11:58
od Celeron
Mam tu velkoplosny supersvitivy Led cip LCOB25-05WO-NWX. Je to livanec prumeru 25 mm na keramicke podlozce na ktere jsou naparene vyvody. Chtel bych se zeptat cim a jak pajet privody aby se neodparily privody na te keramice. Cip se taky musi chladit. Nemate nekdo odzkousene nejake teplovodive lepeni keramika - hlinik?
Diky
Napsal: 29 pro 2011, 15:06
od Atlan
no neviem...ale nepouzivaju sa na napajanie takeho niečoho pruzinky alebo naprucene dotyky...
Napsal: 30 pro 2011, 00:24
od vaanja
Co som sa docital, tak sa to spajkuje:
Connection
Solder the part with a thermo controlled iron, (tip temperature 380°C), within 10 seconds per pad. Use a
backer material whose thermal conductivity will not radiate the heat from soldering.
Avoid touching the yellow phosphor with soldering iron.
http://www.cob-led.com/ceramic-cob-led- ... Module.pdf
