Spravne suciastky
Napsal: 21 dub 2017, 20:45
Caute
Nenasiel by sa tu niekdo ochotny mi ppomoct so spravnim vyberom suciastok pre riadiacu jednotku schodou. Schema a plosak som nasiel na nete. Nerad by som nakupil nespravne suciastky. Vopred dakujem
Kód: Vybrat vše
Partlist
Exported from schody.sch at 21.4.2017 21:12:42
EAGLE Version 7.2.0 Copyright (c) 1988-2014 CadSoft
Assembly variant:
Part Value Device Package Library Sheet
C1 22pF C-EU025-024X044 C025-024X044 rcl 1
C2 22pF C-EU025-024X044 C025-024X044 rcl 1
C3 100nF C-EU025-024X044 C025-024X044 rcl 1
C4 100nF C-EU025-024X044 C025-024X044 rcl 1
C5 1000uF CPOL-EUE1.8-4 E1,8-4 rcl 1
C6 1000uF CPOL-EUE1.8-4 E1,8-4 rcl 1
C7 100nF C-EU025-024X044 C025-024X044 rcl 1
C8 100nF C-EU025-024X044 C025-024X044 rcl 1
C9 200nF C-EU025-024X044 C025-024X044 rcl 1
C10 200nF C-EU025-024X044 C025-024X044 rcl 1
C14 200nF C-EU025-024X044 C025-024X044 rcl 1
C15 200nF C-EU025-024X044 C025-024X044 rcl 1
IC1 TLC5940 IC-PACKAGE_DIL28-3 IC-PACKAGE_DIL28-3 TLC5940 1
IC2 ATMEGA328P-PUPTH ATMEGA328P-PUPTH DIL28-3 Restful_Network_relay 1
IC3 7805TV 7805TV TO220V linear 1
IC4 TLC5940 IC-PACKAGE_DIL28-3 IC-PACKAGE_DIL28-3 TLC5940 1
Q1 IRF512 IRF512 TO220BV transistor-power 1
Q2 IRF512 IRF512 TO220BV transistor-power 1
Q3 IRF512 IRF512 TO220BV transistor-power 1
Q4 IRF512 IRF512 TO220BV transistor-power 1
Q5 IRF512 IRF512 TO220BV transistor-power 1
Q6 IRF512 IRF512 TO220BV transistor-power 1
Q7 IRF512 IRF512 TO220BV transistor-power 1
Q8 IRF512 IRF512 TO220BV transistor-power 1
Q9 16MHz CRYSTALHC49U-V HC49U-V crystal 1
Q10 IRF512 IRF512 TO220BV transistor-power 1
Q11 IRF512 IRF512 TO220BV transistor-power 1
Q12 IRF512 IRF512 TO220BV transistor-power 1
Q13 IRF512 IRF512 TO220BV transistor-power 1
Q14 IRF512 IRF512 TO220BV transistor-power 1
Q15 IRF512 IRF512 TO220BV transistor-power 1
Q16 IRF512 IRF512 TO220BV transistor-power 1
Q17 IRF512 IRF512 TO220BV transistor-power 1
Q18 IRF512 IRF512 TO220BV transistor-power 1
Q19 IRF512 IRF512 TO220BV transistor-power 1
Q20 IRF512 IRF512 TO220BV transistor-power 1
Q21 IRF512 IRF512 TO220BV transistor-power 1
Q22 IRF512 IRF512 TO220BV transistor-power 1
Q23 IRF512 IRF512 TO220BV transistor-power 1
Q24 IRF512 IRF512 TO220BV transistor-power 1
Q26 IRF512 IRF512 TO220BV transistor-power 1
R12 10k R-EU_0204/7 0204/7 rcl 1
R13 10k R-EU_0204/7 0204/7 rcl 1
R30 10k R-EU_0204/7 0204/7 rcl 1
R31 10k R-EU_0204/7 0204/7 rcl 1
R32 10k R-EU_0204/7 0204/7 rcl 1
R33 10k R-EU_0204/7 0204/7 rcl 1
RN1 8x10k G08R SIL9 resistor-sil 1
RN2 8x10k G08R SIL9 resistor-sil 1
RN3 8x10k G08R SIL9 resistor-sil 1
X1 AK300/2 AK300/2 con-ptr500 1
X2 AK300/2 AK300/2 con-ptr500 1
X3 AK300/2 AK300/2 con-ptr500 1
X4 AK300/2 AK300/2 con-ptr500 1
X5 AK300/2 AK300/2 con-ptr500 1
X6 AK300/2 AK300/2 con-ptr500 1
X7 AK300/2 AK300/2 con-ptr500 1
X8 AK300/2 AK300/2 con-ptr500 1
X9 AK300/2 AK300/2 con-ptr500 1
X10 AK300/2 AK300/2 con-ptr500 1
X11 AK300/2 AK300/2 con-ptr500 1
X12 AK300/3 AK300/3 con-ptr500 1
X13 AK300/2 AK300/2 con-ptr500 1
X14 AK300/2 AK300/2 con-ptr500 1
X15 AK300/2 AK300/2 con-ptr500 1
X16 AK300/2 AK300/2 con-ptr500 1
X17 AK300/3 AK300/3 con-ptr500 1
X18 AK300/3 AK300/3 con-ptr500 1
X19 AK300/3 AK300/3 con-ptr500 1
X20 AK300/3 AK300/3 con-ptr500 1
X21 AK300/3 AK300/3 con-ptr500 1
X28 AK300/2 AK300/2 con-ptr500 1
