Po zapnuti len svieti zelena LED na ethernet konektore a blika oranzova. Na seriovej konzole (J501) vidno, ze sa to dokola restartuje - toto sa vypisuje donekonecna:
Kód: Vybrat vše
BCM73580001
1 00000001
234#!@
M0
SHMOO
WLCT 0000000001
SHMOO VER MSA 16b 1.12
PKID 16020112 20120406 003B6000 003B0000 001B103F 00001C00
S300001CF
S00001400
RDLY WL 0 0000000004
RDEN WL 0 0000000050
RDQS WL 0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-
01 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++--
02 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
03 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
04 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
05 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++--
06 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
07 ----------+++++++++++++++++++++++++++X+++++++++++++++++++++++++-
08 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
09 ---------------------------------------------------------------X
10 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
11 -------------+++++++++++++++++++++++X++++++++++++++++++++++-----
12 ---------+++++++++++++++++++++++++X+++++++++++++++++++++++++----
13 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
14 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
15 ------------++++++++++++++++++++++X+++++++++++++++++++++--------
P WL 0
00 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
01 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
03 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
04 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
05 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
06 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++
07 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
08 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
10 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++
12 ----------+++++++++++++++++++++++++++X++++++++++++++++++++++++++
13 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
14 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
15 ------------++++++++++++++++++++++++++X+++++++++++++++++++++++++
N WL 0
00 ---++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-
01 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
02 -------++++++++++++++++++++++++++++X++++++++++++++++++++++++++++
03 --++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----
04 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
05 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--
06 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----
07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-
08 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
10 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--
11 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
12 ++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----
13 +++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-----
14 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----
15 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
WRDQ WL 0
00 ++++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++
01 +++++++++++++++++++++++++X++++++++++++++++++++++++-----+++++++++
02 +++++++++++++++++++++++++X++++++++++++++++++++++++----++++++++++
03 +++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++
04 +++++++++++++++++++++++X++++++++++++++++++++++---------+++++++++
05 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
06 ++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++++
07 +++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++++
08 +++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++++
09 X---------------------------------------------------------------
10 ++++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++
11 +++++++++++++++++++++++X++++++++++++++++++++++---------+++++++++
12 +++++++++++++++++++++++++X++++++++++++++++++++++++----++++++++++
13 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
14 ++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++++
15 +++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++
WRDM WL 0 0000000023
WRDM WL 0 0000000020
ADDR
00 X-------------------S-------------------------------------------
B03B6054
567Bol vadny elyt C901 (220uF/16V), po vymene ziadna zmena. Je tam ale len 0,96 V, co sa mi nezda. Vyzera to ako napajanie CPU - netusi niekto, ake tam ma byt napatie? Na CPU je nalepeny chladic, takze nezistim ani jeho typ...
