termit256 píše:Na ten trim pozor. Nektere SSD ho vubec nepouzivaji a muzes je udajne nejakymi pokusy s timto dokonce znicit.
Tak stary ten SSD zas nebyl, nejake problemy ohledne trimu byly u nakych SSD, ale pouze v rezimu NCQ/AHCI, to sem tam nemel.
termit256 píše:... ja mam novy a pomerne drahy SSD disk od intelu ktery trim nepouziva ...
What operating systems does Intel® Optane™ memory support when used for system acceleration?
Intel® Optane™ memory requires Windows 10 64-bit to be used as a system accelerator.
Is Linux* supported when using Intel® Optane™ memory for system acceleration?
No, the accelerated SATA drive must be running Windows 10 64-bit.
