The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
Zprovoznění HP iPAQ H1900
- comantelix
- comantelix
