Rolovacie koliesko u touchpadu, inštalácia driveru
asdf
#46 Příspěvek od asdf »
Hmm, to je blbý. Víc mě nenapadá. Já ten notebook nemám, tak to nevyzkouším.
#47 Příspěvek od rnbw »
Daj sem vypis dmesg. Tam by malo byt vidiet, ci sa vobec driver inicializuje.
Duvsan
#48 Příspěvek od Duvsan »
    [ 0.333796] ACPI: EC: interrupt blocked
    [ 0.333827] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
    [ 0.333831] ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC used to handle transactions
    [ 0.333833] ACPI: Interpreter enabled
    [ 0.333865] ACPI: PM: (supports S0 S3 S4 S5)
    [ 0.333868] ACPI: Using IOAPIC for interrupt routing
    [ 0.334713] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
    [ 0.334716] PCI: Using E820 reservations for host bridge windows
    [ 0.335028] ACPI: Enabled 12 GPEs in block 00 to 3F
    [ 0.348625] acpi LNXIOBAY:00: ACPI dock station (docks/bays count: 1)
    [ 0.349714] acpi PNP0C15:00: ACPI dock station (docks/bays count: 2)
    [ 0.350690] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
    [ 0.350700] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
    [ 0.350709] acpi PNP0A08:00: _OSC: OS requested [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
    [ 0.350711] acpi PNP0A08:00: _OSC: platform willing to grant [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
    [ 0.350713] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_NOT_FOUND)
    [ 0.351718] PCI host bridge to bus 0000:00
    [ 0.351722] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
    [ 0.351725] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
    [ 0.351727] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
    [ 0.351730] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000dbfff window]
    [ 0.351732] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfeafffff window]
    [ 0.351735] pci_bus 0000:00: root bus resource [bus 00-fe]
    [ 0.351764] pci 0000:00:00.0: [8086:0044] type 00 class 0x060000 conventional PCI endpoint
    [ 0.351790] pci 0000:00:00.0: DMAR: BIOS has allocated no shadow GTT; disabling IOMMU for graphics
    [ 0.351864] pci 0000:00:02.0: [8086:0046] type 00 class 0x030000 conventional PCI endpoint
    [ 0.351875] pci 0000:00:02.0: BAR 0 [mem 0xf2000000-0xf23fffff 64bit]
    [ 0.351881] pci 0000:00:02.0: BAR 2 [mem 0xd0000000-0xdfffffff 64bit pref]
    [ 0.351886] pci 0000:00:02.0: BAR 4 [io 0x1800-0x1807]
    [ 0.351901] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
    [ 0.352035] pci 0000:00:16.0: [8086:3b64] type 00 class 0x078000 conventional PCI endpoint
    [ 0.352061] pci 0000:00:16.0: BAR 0 [mem 0xf2727800-0xf272780f 64bit]
    [ 0.352151] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
    [ 0.352216] pci 0000:00:16.2: [8086:3b66] type 00 class 0x010185 conventional PCI endpoint
    [ 0.352233] pci 0000:00:16.2: BAR 0 [io 0x1828-0x182f]
    [ 0.352243] pci 0000:00:16.2: BAR 1 [io 0x180c-0x180f]
    [ 0.352253] pci 0000:00:16.2: BAR 2 [io 0x1820-0x1827]
    [ 0.352262] pci 0000:00:16.2: BAR 3 [io 0x1808-0x180b]
    [ 0.352270] pci 0000:00:16.2: BAR 4 [io 0x1810-0x181f]
    [ 0.352379] pci 0000:00:16.3: [8086:3b67] type 00 class 0x070002 conventional PCI endpoint
    [ 0.352397] pci 0000:00:16.3: BAR 0 [io 0x1830-0x1837]
    [ 0.352407] pci 0000:00:16.3: BAR 1 [mem 0xf2724000-0xf2724fff]
    [ 0.352552] pci 0000:00:19.0: [8086:10ea] type 00 class 0x020000 conventional PCI endpoint
    [ 0.352566] pci 0000:00:19.0: BAR 0 [mem 0xf2700000-0xf271ffff]
    [ 0.352574] pci 0000:00:19.0: BAR 1 [mem 0xf2725000-0xf2725fff]
    [ 0.352581] pci 0000:00:19.0: BAR 2 [io 0x1840-0x185f]
    [ 0.352637] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
    [ 0.352742] pci 0000:00:1a.0: [8086:3b3c] type 00 class 0x0c0320 conventional PCI endpoint
    [ 0.352759] pci 0000:00:1a.0: BAR 0 [mem 0xf2728000-0xf27283ff]
    [ 0.352838] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
    [ 0.352951] pci 0000:00:1b.0: [8086:3b56] type 00 class 0x040300 PCIe Root Complex Integrated Endpoint
    [ 0.352969] pci 0000:00:1b.0: BAR 0 [mem 0xf2720000-0xf2723fff 64bit]
    [ 0.353043] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
    [ 0.353167] pci 0000:00:1c.0: [8086:3b4c] type 01 class 0x060400 PCIe Root Port
    [ 0.353193] pci 0000:00:1c.0: PCI bridge to [bus 08-0f]
    [ 0.353198] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
    [ 0.353202] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf1ffffff]
    [ 0.353259] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
    [ 0.353371] pci 0000:00:1c.1: [8086:3b44] type 01 class 0x060400 PCIe Root Port
    [ 0.353397] pci 0000:00:1c.1: PCI bridge to [bus 10-17]
    [ 0.353404] pci 0000:00:1c.1: bridge window [mem 0xf2400000-0xf24fffff]
    [ 0.353461] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
    [ 0.353590] pci 0000:00:1d.0: [8086:3b34] type 00 class 0x0c0320 conventional PCI endpoint
    [ 0.353606] pci 0000:00:1d.0: BAR 0 [mem 0xf2728400-0xf27287ff]
    [ 0.353686] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
    [ 0.353795] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060401 conventional PCI bridge
    [ 0.353819] pci 0000:00:1e.0: PCI bridge to [bus 48] (subtractive decode)
    [ 0.353947] pci 0000:00:1f.0: [8086:3b07] type 00 class 0x060100 conventional PCI endpoint
    [ 0.354208] pci 0000:00:1f.2: [8086:3b2f] type 00 class 0x010601 conventional PCI endpoint
    [ 0.354222] pci 0000:00:1f.2: BAR 0 [io 0x1888-0x188f]
    [ 0.354229] pci 0000:00:1f.2: BAR 1 [io 0x183c-0x183f]
    [ 0.354236] pci 0000:00:1f.2: BAR 2 [io 0x1880-0x1887]
    [ 0.354243] pci 0000:00:1f.2: BAR 3 [io 0x1838-0x183b]
    [ 0.354250] pci 0000:00:1f.2: BAR 4 [io 0x1860-0x187f]
    [ 0.354257] pci 0000:00:1f.2: BAR 5 [mem 0xf2727000-0xf27277ff]
    [ 0.354296] pci 0000:00:1f.2: PME# supported from D3hot
    [ 0.354393] pci 0000:00:1f.3: [8086:3b30] type 00 class 0x0c0500 conventional PCI endpoint
    [ 0.354410] pci 0000:00:1f.3: BAR 0 [mem 0xf2728800-0xf27288ff 64bit]
    [ 0.354429] pci 0000:00:1f.3: BAR 4 [io 0x18a0-0x18bf]
    [ 0.354545] pci 0000:00:1f.6: [8086:3b32] type 00 class 0x118000 conventional PCI endpoint
    [ 0.354565] pci 0000:00:1f.6: BAR 0 [mem 0xf2726000-0xf2726fff 64bit]
    [ 0.354779] acpiphp: Slot [1] registered
    [ 0.354785] pci 0000:00:1c.0: PCI bridge to [bus 08-0f]
    [ 0.354924] pci 0000:10:00.0: [8086:08b3] type 00 class 0x028000 PCIe Endpoint
    [ 0.354972] pci 0000:10:00.0: BAR 0 [mem 0xf2400000-0xf2401fff 64bit]
    [ 0.355199] pci 0000:10:00.0: PME# supported from D0 D3hot D3cold
    [ 0.355535] pci 0000:00:1c.1: PCI bridge to [bus 10-17]
    [ 0.355560] pci_bus 0000:48: extended config space not accessible
    [ 0.355611] pci 0000:00:1e.0: PCI bridge to [bus 48] (subtractive decode)
    [ 0.355620] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
    [ 0.355622] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
    [ 0.355624] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
    [ 0.355626] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000dbfff window] (subtractive decode)
    [ 0.355628] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xfeafffff window] (subtractive decode)
    [ 0.356197] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
    [ 0.356277] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
    [ 0.356354] ACPI: PCI: Interrupt link LNKC configured for IRQ 5
    [ 0.356433] ACPI: PCI: Interrupt link LNKD configured for IRQ 11
    [ 0.356509] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
    [ 0.356511] ACPI: PCI: Interrupt link LNKE disabled
    [ 0.356591] ACPI: PCI: Interrupt link LNKF configured for IRQ 10
    [ 0.356668] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
    [ 0.356744] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
    [ 0.356746] ACPI: PCI: Interrupt link LNKH disabled
    [ 0.357574] ACPI: PCI Root Bridge [CPBG] (domain 0000 [bus ff])
    [ 0.357581] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
    [ 0.357703] PCI host bridge to bus 0000:ff
    [ 0.357706] pci_bus 0000:ff: root bus resource [bus ff]
    [ 0.357716] pci 0000:ff:00.0: [8086:2c62] type 00 class 0x060000 conventional PCI endpoint
    [ 0.357774] pci 0000:ff:00.1: [8086:2d01] type 00 class 0x060000 conventional PCI endpoint
    [ 0.357866] pci 0000:ff:02.0: [8086:2d10] type 00 class 0x060000 conventional PCI endpoint
    [ 0.357921] pci 0000:ff:02.1: [8086:2d11] type 00 class 0x060000 conventional PCI endpoint
    [ 0.357977] pci 0000:ff:02.2: [8086:2d12] type 00 class 0x060000 conventional PCI endpoint
    [ 0.358029] pci 0000:ff:02.3: [8086:2d13] type 00 class 0x060000 conventional PCI endpoint
    [ 0.358610] ACPI: EC: interrupt unblocked
    [ 0.358613] ACPI: EC: event unblocked
    [ 0.358616] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
    [ 0.358618] ACPI: EC: GPE=0x17
    [ 0.358620] ACPI: \_SB_.PCI0.LPCB.EC__: Boot DSDT EC initialization complete
    [ 0.358622] ACPI: \_SB_.PCI0.LPCB.EC__: EC: Used to handle transactions and events
    [ 0.358737] iommu: Default domain type: Translated
    [ 0.358737] iommu: DMA domain TLB invalidation policy: lazy mode
    [ 0.358811] SCSI subsystem initialized
    [ 0.358823] libata version 3.00 loaded.
    [ 0.358823] ACPI: bus type USB registered
    [ 0.358823] usbcore: registered new interface driver usbfs
    [ 0.358823] usbcore: registered new interface driver hub
    [ 0.358823] usbcore: registered new device driver usb
    [ 0.358823] pps_core: LinuxPPS API ver. 1 registered
    [ 0.358823] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [ 0.358823] PTP clock support registered
    [ 0.358823] EDAC MC: Ver: 3.0.0
    [ 0.359840] NetLabel: Initializing
    [ 0.359843] NetLabel: domain hash size = 128
    [ 0.359845] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
    [ 0.359874] NetLabel: unlabeled traffic allowed by default
    [ 0.359903] mctp: management component transport protocol core
    [ 0.359903] NET: Registered PF_MCTP protocol family
    [ 0.359903] PCI: Using ACPI for IRQ routing
    [ 0.365875] PCI: pci_cache_line_size set to 64 bytes
    [ 0.365942] e820: reserve RAM buffer [mem 0x0009bc00-0x0009ffff]
    [ 0.365944] e820: reserve RAM buffer [mem 0xba94d000-0xbbffffff]
    [ 0.365947] e820: reserve RAM buffer [mem 0xbb27c000-0xbbffffff]
    [ 0.365949] e820: reserve RAM buffer [mem 0xbb3cb000-0xbbffffff]
    [ 0.365951] e820: reserve RAM buffer [mem 0xbb64f000-0xbbffffff]
    [ 0.365953] e820: reserve RAM buffer [mem 0xbb717000-0xbbffffff]
    [ 0.365955] e820: reserve RAM buffer [mem 0xbb76f000-0xbbffffff]
    [ 0.365957] e820: reserve RAM buffer [mem 0xbb7df000-0xbbffffff]
    [ 0.365958] e820: reserve RAM buffer [mem 0xbb800000-0xbbffffff]
    [ 0.365985] pci 0000:00:02.0: vgaarb: setting as boot VGA device
    [ 0.365985] pci 0000:00:02.0: vgaarb: bridge control possible
    [ 0.365985] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
    [ 0.365985] vgaarb: loaded
    [ 0.365985] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
    [ 0.365985] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
    [ 0.367792] clocksource: Switched to clocksource tsc-early
    [ 0.369025] VFS: Disk quotas dquot_6.6.0
    [ 0.369067] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [ 0.369301] AppArmor: AppArmor Filesystem Enabled
    [ 0.369335] pnp: PnP ACPI init
    [ 0.369499] system 00:00: [io 0x0400-0x047f] has been reserved
    [ 0.369504] system 00:00: [io 0x0480-0x048f] has been reserved
    [ 0.369508] system 00:00: [io 0x04d0-0x04d1] has been reserved
    [ 0.369510] system 00:00: [io 0x0680-0x069f] has been reserved
    [ 0.369512] system 00:00: [io 0x0500-0x050f] has been reserved
    [ 0.369514] system 00:00: [io 0x0600-0x0603] has been reserved
    [ 0.369516] system 00:00: [io 0x0800-0x080f] has been reserved
    [ 0.369519] system 00:00: [io 0x0f40-0x0f41] has been reserved
    [ 0.369524] system 00:00: [io 0x1100-0x111f] has been reserved
    [ 0.369526] system 00:00: [io 0x1180-0x11ff] has been reserved
    [ 0.369529] system 00:00: [io 0x1640-0x164f] has been reserved
    [ 0.369531] system 00:00: [io 0xf800-0xf87f] has been reserved
    [ 0.369533] system 00:00: [io 0xf880-0xf8ff] has been reserved
    [ 0.369535] system 00:00: [io 0xfc00-0xfc7f] has been reserved
    [ 0.369537] system 00:00: [io 0xfc80-0xfcff] has been reserved
    [ 0.369539] system 00:00: [io 0xfd00-0xfd7f] has been reserved
    [ 0.369918] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved
    [ 0.369922] system 00:01: [mem 0xfed10000-0xfed13fff] has been reserved
    [ 0.369924] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved
    [ 0.369926] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved
    [ 0.369928] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
    [ 0.369931] system 00:01: [mem 0x00000000-0x00000fff] could not be reserved
    [ 0.369933] system 00:01: [mem 0xfeaff000-0xfeafffff] has been reserved
    [ 0.369935] system 00:01: [mem 0xfed20000-0xfed3ffff] has been reserved
    [ 0.369937] system 00:01: [mem 0xfed45000-0xfed8ffff] has been reserved
    [ 0.369939] system 00:01: [mem 0xff000000-0xffffffff] has been reserved
    [ 0.369942] system 00:01: [mem 0xfee00000-0xfeefffff] could not be reserved
    [ 0.369944] system 00:01: [mem 0xfef00000-0xfeffffff] has been reserved
    [ 0.370425] system 00:06: [mem 0xfed00000-0xfed003ff] has been reserved
    [ 0.371868] pnp: PnP ACPI: found 9 devices
    [ 0.378523] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
    [ 0.378763] NET: Registered PF_INET protocol family
    [ 0.378877] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [ 0.400740] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [ 0.400795] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [ 0.400852] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [ 0.401054] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [ 0.401320] TCP: Hash tables configured (established 32768 bind 32768)
    [ 0.401484] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
    [ 0.401541] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [ 0.401580] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [ 0.401714] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [ 0.401728] NET: Registered PF_XDP protocol family
    [ 0.401742] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 08-0f] add_size 200000 add_align 100000
    [ 0.401749] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 10-17] add_size 1000
    [ 0.401752] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 10-17] add_size 200000 add_align 100000
    [ 0.401767] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xc01fffff 64bit pref]: assigned
    [ 0.401771] pci 0000:00:1c.1: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]: assigned
    [ 0.401776] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]: assigned
    [ 0.401781] pci 0000:00:1c.0: PCI bridge to [bus 08-0f]
    [ 0.401785] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
    [ 0.401790] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf1ffffff]
    [ 0.401794] pci 0000:00:1c.0: bridge window [mem 0xc0000000-0xc01fffff 64bit pref]
    [ 0.401799] pci 0000:00:1c.1: PCI bridge to [bus 10-17]
    [ 0.401802] pci 0000:00:1c.1: bridge window [io 0x3000-0x3fff]
    [ 0.401806] pci 0000:00:1c.1: bridge window [mem 0xf2400000-0xf24fffff]
    [ 0.401809] pci 0000:00:1c.1: bridge window [mem 0xc0200000-0xc03fffff 64bit pref]
    [ 0.401815] pci 0000:00:1e.0: PCI bridge to [bus 48]
    [ 0.401825] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
    [ 0.401827] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
    [ 0.401829] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
    [ 0.401831] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000dbfff window]
    [ 0.401833] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xfeafffff window]
    [ 0.401835] pci_bus 0000:08: resource 0 [io 0x2000-0x2fff]
    [ 0.401837] pci_bus 0000:08: resource 1 [mem 0xf0000000-0xf1ffffff]
    [ 0.401838] pci_bus 0000:08: resource 2 [mem 0xc0000000-0xc01fffff 64bit pref]
    [ 0.401841] pci_bus 0000:10: resource 0 [io 0x3000-0x3fff]
    [ 0.401842] pci_bus 0000:10: resource 1 [mem 0xf2400000-0xf24fffff]
    [ 0.401844] pci_bus 0000:10: resource 2 [mem 0xc0200000-0xc03fffff 64bit pref]
    [ 0.401847] pci_bus 0000:48: resource 4 [io 0x0000-0x0cf7 window]
    [ 0.401848] pci_bus 0000:48: resource 5 [io 0x0d00-0xffff window]
    [ 0.401850] pci_bus 0000:48: resource 6 [mem 0x000a0000-0x000bffff window]
    [ 0.401852] pci_bus 0000:48: resource 7 [mem 0x000d4000-0x000dbfff window]
    [ 0.401854] pci_bus 0000:48: resource 8 [mem 0xc0000000-0xfeafffff window]
    [ 0.402003] pci 0000:00:02.0: BIOS left Intel GPU interrupts enabled; disabling
    [ 0.402728] PCI: CLS 64 bytes, default 64
    [ 0.402740] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
    [ 0.402742] software IO TLB: mapped [mem 0x00000000b694d000-0x00000000ba94d000] (64MB)
    [ 0.402845] Trying to unpack rootfs image as initramfs...
    [ 0.406329] Initialise system trusted keyrings
    [ 0.406356] Key type blacklist registered
    [ 0.406517] workingset: timestamp_bits=36 max_order=20 bucket_order=0
    [ 0.406557] zbud: loaded
    [ 0.409591] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.410857] fuse: init (API version 7.39)
    [ 0.411365] integrity: Platform Keyring initialized
    [ 0.411385] integrity: Machine keyring initialized
    [ 0.433261] Key type asymmetric registered
    [ 0.433272] Asymmetric key parser 'x509' registered
    [ 0.433349] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [ 0.433518] io scheduler mq-deadline registered
    [ 0.434508] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
    [ 0.437436] ACPI: AC: AC Adapter [AC] (on-line)
    [ 0.437646] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
    [ 0.437791] ACPI: button: Lid Switch [LID]
    [ 0.437894] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
    [ 0.437970] ACPI: button: Power Button [PWRB]
    [ 0.438056] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
    [ 0.438112] ACPI: button: Sleep Button [SLPB]
    [ 0.438194] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
    [ 0.438325] ACPI: button: Power Button [PWRF]
    [ 0.439473] ACPI: battery: Slot [CMB1] (battery absent)
    [ 0.439553] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
    [ 0.439595] ACPI: battery: Slot [CMB2] (battery absent)
    [ 0.460429] 00:07: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
    [ 0.490078] 0000:00:16.3: ttyS4 at I/O 0x1830 (irq = 17, base_baud = 115200) is a 16550A
    [ 0.491365] Linux agpgart interface v0.103
    [ 0.495940] tpm_tis 00:02: 1.2 TPM (device-id 0xB, rev-id 16)
    [ 0.524937] tpm tpm0: TPM is disabled/deactivated (0x7)
    [ 0.537632] loop: module loaded
    [ 0.539526] scsi host0: ata_generic
    [ 0.540096] scsi host1: ata_generic
    [ 0.540240] ata1: PATA max UDMA/100 cmd 0x1828 ctl 0x180c bmdma 0x1810 irq 18 lpm-pol 0
    [ 0.540248] ata2: PATA max UDMA/100 cmd 0x1820 ctl 0x1808 bmdma 0x1818 irq 18 lpm-pol 0
    [ 0.540360] ACPI: bus type drm_connector registered
    [ 0.540982] tun: Universal TUN/TAP device driver, 1.6
    [ 0.541148] PPP generic driver version 2.4.2
    [ 0.541556] i8042: PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
    [ 0.541804] ehci-pci 0000:00:1a.0: EHCI Host Controller
    [ 0.541823] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
    [ 0.541838] ehci-pci 0000:00:1a.0: debug port 2
    [ 0.545921] ehci-pci 0000:00:1a.0: irq 22, io mem 0xf2728000
    [ 0.547956] i8042: Detected active multiplexing controller, rev 1.1
    [ 0.549370] serio: i8042 KBD port at 0x60,0x64 irq 1
    [ 0.549388] serio: i8042 AUX0 port at 0x60,0x64 irq 12
    [ 0.549395] serio: i8042 AUX1 port at 0x60,0x64 irq 12
    [ 0.549399] serio: i8042 AUX2 port at 0x60,0x64 irq 12
    [ 0.549404] serio: i8042 AUX3 port at 0x60,0x64 irq 12
    [ 0.549737] mousedev: PS/2 mouse device common for all mice
    [ 0.550301] rtc_cmos 00:05: RTC can wake from S4
    [ 0.550749] rtc_cmos 00:05: registered as rtc0
    [ 0.550789] rtc_cmos 00:05: setting system clock to 2024-06-26T07:56:26 UTC (1719388586)
    [ 0.550871] rtc_cmos 00:05: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
    [ 0.550899] i2c_dev: i2c /dev entries driver
    [ 0.550968] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
    [ 0.551046] device-mapper: uevent: version 1.0.3
    [ 0.551229] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
    [ 0.551296] platform eisa.0: Probing EISA bus 0
    [ 0.551315] platform eisa.0: EISA: Cannot allocate resource for mainboard
    [ 0.551320] platform eisa.0: Cannot allocate resource for EISA slot 1
    [ 0.551324] platform eisa.0: Cannot allocate resource for EISA slot 2
    [ 0.551327] platform eisa.0: Cannot allocate resource for EISA slot 3
    [ 0.551331] platform eisa.0: Cannot allocate resource for EISA slot 4
    [ 0.551334] platform eisa.0: Cannot allocate resource for EISA slot 5
    [ 0.551338] platform eisa.0: Cannot allocate resource for EISA slot 6
    [ 0.551342] platform eisa.0: Cannot allocate resource for EISA slot 7
    [ 0.551345] platform eisa.0: Cannot allocate resource for EISA slot 8
    [ 0.551348] platform eisa.0: EISA: Detected 0 cards
    [ 0.551355] intel_pstate: CPU model not supported
    [ 0.551671] ledtrig-cpu: registered to indicate activity on CPUs
    [ 0.552209] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
    [ 0.552685] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
    [ 0.553038] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
    [ 0.553050] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.553058] usb usb1: Product: EHCI Host Controller
    [ 0.553064] usb usb1: Manufacturer: Linux 6.8.0-35-generic ehci_hcd
    [ 0.553070] usb usb1: SerialNumber: 0000:00:1a.0
    [ 0.553333] fbcon: Deferring console take-over
    [ 0.553342] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
    [ 0.553507] hub 1-0:1.0: USB hub found
    [ 0.553528] hub 1-0:1.0: 3 ports detected
    [ 0.553550] drop_monitor: Initializing network drop monitor service
    [ 0.554091] ehci-pci 0000:00:1d.0: EHCI Host Controller
    [ 0.554105] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
    [ 0.554128] ehci-pci 0000:00:1d.0: debug port 2
    [ 0.558270] ehci-pci 0000:00:1d.0: irq 22, io mem 0xf2728400
    [ 0.558275] NET: Registered PF_INET6 protocol family
    [ 0.564863] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
    [ 0.565035] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.08
    [ 0.565043] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [ 0.565048] usb usb2: Product: EHCI Host Controller
    [ 0.565052] usb usb2: Manufacturer: Linux 6.8.0-35-generic ehci_hcd
    [ 0.565056] usb usb2: SerialNumber: 0000:00:1d.0
    [ 0.565451] hub 2-0:1.0: USB hub found
    [ 0.565477] hub 2-0:1.0: 3 ports detected
    [ 0.569968] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
    [ 0.702671] Freeing initrd memory: 64088K
    [ 0.715532] Segment Routing with IPv6
    [ 0.715598] In-situ OAM (IOAM) with IPv6
    [ 0.715677] NET: Registered PF_PACKET protocol family
    [ 0.715794] Key type dns_resolver registered
    [ 0.716619] microcode: Current revision: 0x00000011
    [ 0.716625] microcode: Updated early from: 0x00000009
    [ 0.716837] IPI shorthand broadcast: enabled
    [ 0.722126] sched_clock: Marking stable (720641173, 852999)->(734512685, -13018513)
    [ 0.722706] registered taskstats version 1
    [ 0.723383] Loading compiled-in X.509 certificates
    [ 0.725760] Loaded X.509 cert 'Build time autogenerated kernel key: 03e06390aec9ad5e857c861e6f9847fee1cbfc2d'
    [ 0.727782] Loaded X.509 cert 'Canonical Ltd. Live Patch Signing: 14df34d1a87cf37625abec039ef2bf521249b969'
    [ 0.729773] Loaded X.509 cert 'Canonical Ltd. Kernel Module Signing: 88f752e560a1e0737e31163a466ad7b70a850c19'
    [ 0.729779] blacklist: Loading compiled-in revocation X.509 certificates
    [ 0.729854] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
    [ 0.729909] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2017): 242ade75ac4a15e50d50c84b0d45ff3eae707a03'
    [ 0.729962] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (ESM 2018): 365188c1d374d6b07c3c8f240f8ef722433d6a8b'
    [ 0.730014] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2019): c0746fd6c5da3ae827864651ad66ae47fe24b3e8'
    [ 0.730070] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v1): a8d54bbb3825cfb94fa13c9f8a594a195c107b8d'
    [ 0.730137] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v2): 4cf046892d6fd3c9a5b03f98d845f90851dc6a8c'
    [ 0.730193] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (2021 v3): 100437bb6de6e469b581e61cd66bce3ef4ed53af'
    [ 0.730243] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing (Ubuntu Core 2019): c1d57b8f6b743f23ee41f4f7ee292f06eecadfb9'
    [ 0.742072] Key type .fscrypt registered
    [ 0.742081] Key type fscrypt-provisioning registered
    [ 0.742221] Key type trusted registered
    [ 0.785875] Key type encrypted registered
    [ 0.785896] AppArmor: AppArmor sha256 policy hashing enabled
    [ 0.785941] Loading compiled-in module X.509 certificates
    [ 0.787977] Loaded X.509 cert 'Build time autogenerated kernel key: 03e06390aec9ad5e857c861e6f9847fee1cbfc2d'
    [ 0.787986] ima: Allocated hash algorithm: sha256
    [ 0.792916] ima: Error Communicating to TPM chip
    [ 0.797920] ima: Error Communicating to TPM chip
    [ 0.802914] ima: Error Communicating to TPM chip
    [ 0.806914] ima: Error Communicating to TPM chip
    [ 0.808546] usb 1-1: new high-speed USB device number 2 using ehci-pci
    [ 0.811913] ima: Error Communicating to TPM chip
    [ 0.816544] usb 2-1: new high-speed USB device number 2 using ehci-pci
    [ 0.816913] ima: Error Communicating to TPM chip
    [ 0.821873] ima: Error Communicating to TPM chip
    [ 0.826912] ima: Error Communicating to TPM chip
    [ 0.835955] ima: No architecture policies found
    [ 0.835993] evm: Initialising EVM extended attributes:
    [ 0.835997] evm: security.selinux
    [ 0.836000] evm: security.SMACK64
    [ 0.836002] evm: security.SMACK64EXEC
    [ 0.836003] evm: security.SMACK64TRANSMUTE
    [ 0.836005] evm: security.SMACK64MMAP
    [ 0.836007] evm: security.apparmor
    [ 0.836009] evm: security.ima
    [ 0.836010] evm: security.capability
    [ 0.836012] evm: HMAC attrs: 0x1
    [ 0.836927] PM: Magic number: 12:585:926
    [ 0.852577] RAS: Correctable Errors collector initialized.
    [ 0.852792] clk: Disabling unused clocks
    [ 0.885425] Freeing unused decrypted memory: 2028K
    [ 0.887002] Freeing unused kernel image (initmem) memory: 4976K
    [ 0.887185] Write protecting the kernel read-only data: 36864k
    [ 0.887762] Freeing unused kernel image (rodata/data gap) memory: 44K
    [ 0.939906] usb 1-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
    [ 0.939916] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 0.940809] hub 1-1:1.0: USB hub found
    [ 0.940899] hub 1-1:1.0: 6 ports detected
    [ 0.947900] usb 2-1: New USB device found, idVendor=8087, idProduct=0020, bcdDevice= 0.00
    [ 0.947908] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 0.948659] hub 2-1:1.0: USB hub found
    [ 0.948731] hub 2-1:1.0: 8 ports detected
    [ 0.988072] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [ 0.988081] x86/mm: Checking user space page tables
    [ 1.046300] x86/mm: Checked W+X mappings: passed, no W+X pages found.
    [ 1.046319] Run /init as init process
    [ 1.046323] with arguments:
    [ 1.046325] /init
    [ 1.046326] splash
    [ 1.046328] with environment:
    [ 1.046329] HOME=/
    [ 1.046331] TERM=linux
    [ 1.046332] BOOT_IMAGE=/boot/vmlinuz-6.8.0-35-generic
    [ 1.203882] usb 1-1.6: new high-speed USB device number 3 using ehci-pci
    [ 1.237884] usb 2-1.6: new full-speed USB device number 3 using ehci-pci
    [ 1.289825] e1000e: Intel(R) PRO/1000 Network Driver
    [ 1.289835] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
    [ 1.293156] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
    [ 1.300793] ahci 0000:00:1f.2: version 3.0
    [ 1.301303] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
    [ 1.301338] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 3 Gbps 0x13 impl SATA mode
    [ 1.301345] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pio slum part ems sxs apst
    [ 1.321382] usb 2-1.6: New USB device found, idVendor=8087, idProduct=07dc, bcdDevice= 0.01
    [ 1.321396] usb 2-1.6: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [ 1.323760] scsi host2: ahci
    [ 1.326936] scsi host3: ahci
    [ 1.347754] scsi host4: ahci
    [ 1.348277] scsi host5: ahci
    [ 1.348728] scsi host6: ahci
    [ 1.348965] scsi host7: ahci
    [ 1.349068] ata3: SATA max UDMA/133 abar m2048@0xf2727000 port 0xf2727100 irq 25 lpm-pol 0
    [ 1.349074] ata4: SATA max UDMA/133 abar m2048@0xf2727000 port 0xf2727180 irq 25 lpm-pol 0
    [ 1.349077] ata5: DUMMY
    [ 1.349079] ata6: DUMMY
    [ 1.349081] ata7: SATA max UDMA/133 abar m2048@0xf2727000 port 0xf2727300 irq 25 lpm-pol 0
    [ 1.349084] ata8: DUMMY
    [ 1.438896] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 8c:73:6e:75:d2:b5
    [ 1.438905] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
    [ 1.438946] e1000e 0000:00:19.0 eth0: MAC: 9, PHY: 10, PBA No: FFFFFF-0FF
    [ 1.459904] tsc: Refined TSC clocksource calibration: 2393.996 MHz
    [ 1.459917] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x22820fca205, max_idle_ns: 440795225047 ns
    [ 1.460233] clocksource: Switched to clocksource tsc
    [ 1.545816] usb 1-1.6: New USB device found, idVendor=0bda, idProduct=0138, bcdDevice=38.82
    [ 1.545825] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [ 1.545829] usb 1-1.6: Product: USB2.0-CRW
    [ 1.545832] usb 1-1.6: Manufacturer: Generic
    [ 1.545835] usb 1-1.6: SerialNumber: 20090516388200000
    [ 1.566999] usbcore: registered new interface driver usb-storage
    [ 1.658410] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 1.659618] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
    [ 1.659627] ata3.00: ACPI cmd f5/00:00:00:00:00:a0(SECURITY FREEZE LOCK) filtered out
    [ 1.659792] ata3.00: HPA detected: current 234439535, native 234441648
    [ 1.659803] ata3.00: ATA-7: ST9120822AS, 3.ALD, max UDMA/133
    [ 1.659809] ata3.00: 234439535 sectors, multi 16: LBA48 NCQ (depth 32)
    [ 1.661180] ata3.00: ACPI cmd ef/10:03:00:00:00:a0(SET FEATURES) filtered out
    [ 1.661190] ata3.00: ACPI cmd f5/00:00:00:00:00:a0(SECURITY FREEZE LOCK) filtered out
    [ 1.661317] ata3.00: configured for UDMA/133
    [ 1.661589] scsi 2:0:0:0: Direct-Access ATA ST9120822AS D PQ: 0 ANSI: 5
    [ 1.662261] sd 2:0:0:0: Attached scsi generic sg0 type 0
    [ 1.662270] sd 2:0:0:0: [sda] 234439535 512-byte logical blocks: (120 GB/112 GiB)
    [ 1.662293] sd 2:0:0:0: [sda] Write Protect is off
    [ 1.662304] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [ 1.662347] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 1.662413] sd 2:0:0:0: [sda] Preferred minimum I/O size 512 bytes
    [ 1.712078] sda: sda1 sda2 sda3 sda4
    [ 1.712543] sd 2:0:0:0: [sda] Attached SCSI disk
    [ 1.970569] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 1.989680] ata4.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
    [ 2.007158] ata4.00: ATAPI: TSSTcorp CDDVDW TS-U633F, FU02, max UDMA/100
    [ 2.007171] ata4.00: applying bridge limits
    [ 2.028427] ata4.00: ACPI cmd 00/00:00:00:00:00:a0(NOP) rejected by device (Stat=0x51 Err=0x04)
    [ 2.045931] ata4.00: configured for UDMA/100
    [ 2.053936] scsi 3:0:0:0: CD-ROM TSSTcorp CDDVDW TS-U633F FU02 PQ: 0 ANSI: 5
    [ 2.088455] sr 3:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
    [ 2.088463] cdrom: Uniform CD-ROM driver Revision: 3.20
    [ 2.104284] sr 3:0:0:0: Attached scsi CD-ROM sr0
    [ 2.104492] sr 3:0:0:0: Attached scsi generic sg1 type 5
    [ 2.286985] input: PS/2 Generic Mouse as /devices/platform/i8042/serio3/input/input11
    [ 2.410197] ata7: SATA link down (SStatus 0 SControl 300)
    [ 2.412630] e1000e 0000:00:19.0 enp0s25: renamed from eth0
    [ 2.415829] usbcore: registered new interface driver uas
    [ 2.418103] ums-realtek 1-1.6:1.0: USB Mass Storage device detected
    [ 2.422456] scsi host8: usb-storage 1-1.6:1.0
    [ 2.422649] usbcore: registered new interface driver ums-realtek
    [ 3.013370] psmouse serio4: synaptics: queried max coordinates: x [..5574], y [..4726]
    [ 3.076443] psmouse serio4: synaptics: Touchpad model: 1, fw: 7.4, id: 0x180b1, caps: 0xd04731/0xa42000/0xa0000/0x0, board id: 0, fw id: 631307
    [ 3.117223] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input12
    [ 3.447026] scsi 8:0:0:0: Direct-Access Generic- Multi-Card 1.00 PQ: 0 ANSI: 0 CCS
    [ 3.447556] sd 8:0:0:0: Attached scsi generic sg2 type 0
    [ 3.450302] sd 8:0:0:0: [sdb] Media removed, stopped polling
    [ 3.451119] sd 8:0:0:0: [sdb] Attached SCSI removable disk
    [ 4.021226] random: crng init done
    [ 6.044515] EXT4-fs (sda2): mounted filesystem 61ff8ced-cd9a-487f-9f0e-22a677939d19 ro with ordered data mode. Quota mode: none.
    [ 8.234166] systemd[1]: Inserted module 'autofs4'
    [ 8.499066] systemd[1]: systemd 255.4-1ubuntu8.1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [ 8.499099] systemd[1]: Detected architecture x86-64.
    [ 8.556981] systemd[1]: Hostname set to <S760>.
    [ 11.463737] systemd[1]: Queued start job for default target graphical.target.
    [ 11.529199] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
    [ 11.530466] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
    [ 11.531279] systemd[1]: Created slice user.slice - User and Session Slice.
    [ 11.531491] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
    [ 11.532101] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
    [ 11.532177] systemd[1]: Expecting device dev-disk-by\x2duuid-c687a6b2\x2d0c34\x2d4e14\x2db177\x2d98fd1a545dc5.device - /dev/disk/by-uuid/c687a6b2-0c34-4e14-b177-98fd1a545dc5...
    [ 11.532207] systemd[1]: Expecting device dev-disk-by\x2duuid-f570dbe0\x2deb12\x2d4b10\x2d82fa\x2dc9681f688080.device - /dev/disk/by-uuid/f570dbe0-eb12-4b10-82fa-c9681f688080...
    [ 11.532286] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
    [ 11.532378] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
    [ 11.532426] systemd[1]: Reached target remote-fs.target - Remote File Systems.
    [ 11.532469] systemd[1]: Reached target slices.target - Slice Units.
    [ 11.532518] systemd[1]: Reached target snapd.mounts-pre.target - Mounting snaps.
    [ 11.532612] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
    [ 11.533156] systemd[1]: Listening on syslog.socket - Syslog Socket.
    [ 11.533461] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
    [ 11.533655] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
    [ 11.534034] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
    [ 11.534432] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
    [ 11.534511] systemd[1]: systemd-pcrextend.socket - TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [ 11.534958] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
    [ 11.535320] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
    [ 11.560021] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
    [ 11.561866] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
    [ 11.563062] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
    [ 11.564819] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
    [ 11.570225] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
    [ 11.572412] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
    [ 11.574893] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
    [ 11.577178] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
    [ 11.581580] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
    [ 11.584190] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
    [ 11.591409] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
    [ 11.596096] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
    [ 11.596363] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
    [ 11.602768] systemd[1]: Starting systemd-journald.service - Journal Service...
    [ 11.696297] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
    [ 11.696343] systemd[1]: systemd-pcrmachine.service - TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [ 11.698046] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
    [ 11.698179] systemd[1]: systemd-tpm2-setup-early.service - TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [ 11.700272] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
    [ 11.704266] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
    [ 11.704904] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
    [ 11.705167] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
    [ 11.705423] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
    [ 11.705982] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
    [ 11.706780] systemd[1]: modprobe@configfs.service: Deactivated successfully.
    [ 11.707157] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
    [ 11.707880] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
    [ 11.708131] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
    [ 11.708640] systemd[1]: modprobe@drm.service: Deactivated successfully.
    [ 11.708896] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
    [ 11.709405] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
    [ 11.709649] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
    [ 11.710233] systemd[1]: modprobe@fuse.service: Deactivated successfully.
    [ 11.710478] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
    [ 11.711000] systemd[1]: modprobe@loop.service: Deactivated successfully.
    [ 11.711248] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
    [ 11.713397] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
    [ 11.714665] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
    [ 11.714803] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
    [ 11.719314] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
    [ 11.724778] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
    [ 11.725782] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
    [ 11.850292] EXT4-fs (sda2): re-mounted 61ff8ced-cd9a-487f-9f0e-22a677939d19 r/w. Quota mode: none.
    [ 11.853133] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
    [ 11.912654] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
    [ 11.912762] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
    [ 11.922171] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
    [ 11.922233] systemd[1]: systemd-tpm2-setup.service - TPM2 SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [ 11.972078] systemd-journald[308]: Collecting audit messages is disabled.
    [ 12.078103] systemd[1]: Started systemd-journald.service - Journal Service.
    [ 12.303531] lp: driver loaded but no devices found
    [ 12.320584] systemd-journald[308]: Received client request to flush runtime journal.
    [ 12.340940] ppdev: user-space parallel port driver
    [ 12.389273] parport_pc 00:08: reported by Plug and Play ACPI
    [ 12.389384] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
    [ 12.479276] lp0: using parport0 (interrupt-driven).
    [ 13.054559] systemd-journald[308]: File /var/log/journal/633c72bb7f45440c820585f1ad4be79d/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [ 14.326411] loop0: detected capacity change from 0 to 8
    [ 14.326510] loop1: detected capacity change from 0 to 152040
    [ 14.335530] loop2: detected capacity change from 0 to 552192
    [ 14.401340] loop3: detected capacity change from 0 to 21952
    [ 14.488149] loop4: detected capacity change from 0 to 1034424
    [ 14.500012] loop5: detected capacity change from 0 to 187776
    [ 14.500963] loop6: detected capacity change from 0 to 21216
    [ 14.572248] loop7: detected capacity change from 0 to 79328
    [ 14.634042] loop8: detected capacity change from 0 to 79520
    [ 14.646001] loop9: detected capacity change from 0 to 952
    [ 14.677623] loop10: detected capacity change from 0 to 281176
    [ 14.694787] loop11: detected capacity change from 0 to 284400
    [ 16.056703] intel ips 0000:00:1f.6: CPU TDP doesn't match expected value (found 25, expected 29)
    [ 16.057142] intel ips 0000:00:1f.6: failed to get i915 symbols, graphics turbo disabled until i915 loads
    [ 16.057412] intel ips 0000:00:1f.6: IPS driver initialized, MCP temp limit 90
    [ 16.064311] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\_SB.PCI0.LPCB.PMIO) (20230628/utaddress-204)
    [ 16.064332] ACPI: OSL: Resource conflict; ACPI support missing from driver?
    [ 16.064337] ACPI Warning: SystemIO range 0x00000000000011B0-0x00000000000011BF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\_SB.PCI0.LPCB.OGIO) (20230628/utaddress-204)
    [ 16.064347] ACPI: OSL: Resource conflict; ACPI support missing from driver?
    [ 16.064350] ACPI Warning: SystemIO range 0x0000000000001180-0x00000000000011AF conflicts with OpRegion 0x0000000000001180-0x00000000000011BB (\_SB.PCI0.LPCB.OGIO) (20230628/utaddress-204)
    [ 16.064357] ACPI: OSL: Resource conflict; ACPI support missing from driver?
    [ 16.064417] lpc_ich: Resource conflict(s) found affecting gpio_ich
    [ 16.102440] fujitsu_laptop: ACPI: Fujitsu FUJ02E3 [FEXT]
    [ 16.103665] ACPI: \_SB_.FEXT: BTNI: [0x10f0101]
    [ 16.103770] input: Fujitsu FUJ02E3 as /devices/LNXSYSTM:00/LNXSYBUS:00/FUJ02E3:00/input/input13
    [ 16.105480] fujitsu_laptop: driver 0.6.0 successfully loaded
    [ 16.133575] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
    [ 16.135670] i2c i2c-0: 2/2 memory slots populated (from DMI)
    [ 16.135679] i2c i2c-0: Memory type 0x15 not supported yet, not instantiating SPD
    [ 16.324598] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [ 16.325239] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [ 16.325634] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [ 16.600254] Intel(R) Wireless WiFi driver for Linux
    [ 16.600980] iwlwifi 0000:10:00.0: Detected crf-id 0x0, cnv-id 0x0 wfpm id 0x0
    [ 16.600999] iwlwifi 0000:10:00.0: PCI dev 08b3/0070, rev=0x164, rfid=0xd55555d5
    [ 16.624169] gpio_ich gpio_ich.2.auto: GPIO from 512 to 587
    [ 16.667887] cryptd: max_cpu_qlen set to 1000
    [ 16.978236] iwlwifi 0000:10:00.0: loaded firmware version 17.3216344376.0 3160-17.ucode op_mode iwlmvm
    [ 17.986942] SSE version of gcm_enc/dec engaged.
    [ 18.130457] pci 0000:00:00.0: Intel HD Graphics Chipset
    [ 18.130501] pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
    [ 18.130989] pci 0000:00:00.0: detected 32768K stolen memory
    [ 18.137552] Bluetooth: Core ver 2.22
    [ 18.137600] NET: Registered PF_BLUETOOTH protocol family
    [ 18.137603] Bluetooth: HCI device and connection manager initialized
    [ 18.137612] Bluetooth: HCI socket layer initialized
    [ 18.137617] Bluetooth: L2CAP socket layer initialized
    [ 18.137625] Bluetooth: SCO socket layer initialized
    [ 18.143294] i915 0000:00:02.0: vgaarb: deactivate vga console
    [ 18.177201] i915 0000:00:02.0: [drm] Skipping intel_backlight registration
    [ 18.177727] [drm] Initialized i915 1.6.0 20230929 for 0000:00:02.0 on minor 1
    [ 18.178939] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
    [ 18.179115] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
    [ 18.181663] acpi device:03: registered as cooling_device4
    [ 18.181826] i915 display info: display version: 5
    [ 18.181830] i915 display info: cursor_needs_physical: no
    [ 18.181833] i915 display info: has_cdclk_crawl: no
    [ 18.181835] i915 display info: has_cdclk_squash: no
    [ 18.181838] i915 display info: has_ddi: no
    [ 18.181840] i915 display info: has_dp_mst: no
    [ 18.181842] i915 display info: has_dsb: no
    [ 18.181844] i915 display info: has_fpga_dbg: no
    [ 18.181846] i915 display info: has_gmch: no
    [ 18.181848] i915 display info: has_hotplug: yes
    [ 18.181850] i915 display info: has_hti: no
    [ 18.181852] i915 display info: has_ipc: no
    [ 18.181873] i915 display info: has_overlay: no
    [ 18.181876] i915 display info: has_psr: no
    [ 18.181878] i915 display info: has_psr_hw_tracking: no
    [ 18.181879] i915 display info: overlay_needs_physical: no
    [ 18.181881] i915 display info: supports_tv: no
    [ 18.181883] i915 display info: has_hdcp: no
    [ 18.181884] i915 display info: has_dmc: no
    [ 18.181886] i915 display info: has_dsc: no
    [ 18.195223] fbcon: i915drmfb (fb0) is primary device
    [ 18.195230] fbcon: Deferring console take-over
    [ 18.195237] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
    [ 18.335968] iwlwifi 0000:10:00.0: Detected Intel(R) Dual Band Wireless AC 3160, REV=0x164
    [ 18.355571] iwlwifi 0000:10:00.0: base HW address: 1c:4d:70:e6:d4:9e, OTP minor version: 0x0
    [ 18.463328] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
    [ 18.491227] iwlwifi 0000:10:00.0 wlp16s0: renamed from wlan0
    [ 18.567622] usbcore: registered new interface driver btusb
    [ 18.580588] Bluetooth: hci0: Legacy ROM 2.5 revision 0.0 build 1 week 45 2013
    [ 18.795417] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
    [ 18.990662] Bluetooth: hci0: Intel BT fw patch 0x27 completed & activated
    [ 19.429816] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
    [ 19.577937] input: HDA Intel MID HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
    [ 20.142656] Adding 4102140k swap on /dev/sda3. Priority:-2 extents:1 across:4102140k
    [ 21.460055] intel ips 0000:00:1f.6: i915 driver attached, reenabling gpu turbo
    [ 24.560396] EXT4-fs (sda4): mounted filesystem c687a6b2-0c34-4e14-b177-98fd1a545dc5 r/w with ordered data mode. Quota mode: none.
    [ 25.463317] audit: type=1400 audit(1719388611.411:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="1password" pid=809 comm="apparmor_parser"
    [ 25.463334] audit: type=1400 audit(1719388611.411:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name=4D6F6E676F444220436F6D70617373 pid=811 comm="apparmor_parser"
    [ 25.463340] audit: type=1400 audit(1719388611.411:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="QtWebEngineProcess" pid=812 comm="apparmor_parser"
    [ 25.463346] audit: type=1400 audit(1719388611.411:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="Discord" pid=810 comm="apparmor_parser"
    [ 25.527452] audit: type=1400 audit(1719388611.475:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="brave" pid=813 comm="apparmor_parser"
    [ 25.527467] audit: type=1400 audit(1719388611.475:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="busybox" pid=815 comm="apparmor_parser"
    [ 25.527474] audit: type=1400 audit(1719388611.475:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="buildah" pid=814 comm="apparmor_parser"
    [ 25.528095] audit: type=1400 audit(1719388611.476:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="cam" pid=816 comm="apparmor_parser"
    [ 25.540691] audit: type=1400 audit(1719388611.488:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-checkns" pid=817 comm="apparmor_parser"
    [ 25.540753] audit: type=1400 audit(1719388611.488:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ch-run" pid=818 comm="apparmor_parser"
    [ 30.907547] kauditd_printk_skb: 138 callbacks suppressed
    [ 30.907555] audit: type=1400 audit(1719388616.855:150): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="rsyslogd" pid=999 comm="apparmor_parser"
    [ 37.596843] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [ 37.596869] Bluetooth: BNEP filters: protocol multicast
    [ 37.596883] Bluetooth: BNEP socket layer initialized
    [ 37.600781] Bluetooth: MGMT ver 1.22
    [ 37.671138] NET: Registered PF_ALG protocol family
    [ 45.991463] loop12: detected capacity change from 0 to 8
    [ 46.338601] NET: Registered PF_QIPCRTR protocol family
    [ 49.929877] audit: type=1400 audit(1719388635.877:151): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1162 comm="apparmor_parser"
    [ 49.936789] audit: type=1400 audit(1719388635.884:152): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1162 comm="apparmor_parser"
    [ 52.760973] iwlwifi 0000:10:00.0: Registered PHC clock: iwlwifi-PTP, with index: 0
    [ 54.236057] audit: type=1400 audit(1719388640.184:153): apparmor="DENIED" operation="capable" class="cap" profile="/usr/sbin/cupsd" pid=1234 comm="cupsd" capability=12 capname="net_admin"
    [ 57.081292] wlp16s0: 80 MHz not supported, disabling VHT
    [ 57.084019] wlp16s0: authenticate with 60:32:b1:16:cf:07 (local address=1c:4d:70:e6:d4:9e)
    [ 57.084433] wlp16s0: send auth to 60:32:b1:16:cf:07 (try 1/3)
    [ 57.089776] wlp16s0: authenticated
    [ 57.090923] wlp16s0: associate with 60:32:b1:16:cf:07 (try 1/3)
    [ 57.098506] wlp16s0: RX AssocResp from 60:32:b1:16:cf:07 (capab=0xc11 status=0 aid=5)
    [ 57.104234] wlp16s0: associated
    [ 65.118203] systemd-journald[308]: /var/log/journal/633c72bb7f45440c820585f1ad4be79d/user-1000.journal: Journal file uses a different sequence number ID, rotating.
    [ 68.051688] audit: type=1400 audit(1719388653.999:154): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=1334 comm="snap-confine" capability=12 capname="net_admin"
    [ 68.051706] audit: type=1400 audit(1719388653.999:155): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=1334 comm="snap-confine" capability=38 capname="perfmon"
    [ 71.422371] audit: type=1400 audit(1719388657.370:156): apparmor="DENIED" operation="open" class="file" profile="snap-update-ns.snapd-desktop-integration" name="/proc/1427/maps" pid=1427 comm="5" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
    [ 77.302097] Bluetooth: RFCOMM TTY layer initialized
    [ 77.302121] Bluetooth: RFCOMM socket layer initialized
    [ 77.302141] Bluetooth: RFCOMM ver 1.11
    [ 90.725961] audit: type=1400 audit(1719388676.643:157): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=1753 comm="snap-confine" capability=12 capname="net_admin"
    [ 90.726001] audit: type=1400 audit(1719388676.643:158): apparmor="DENIED" operation="capable" class="cap" profile="/usr/lib/snapd/snap-confine" pid=1753 comm="snap-confine" capability=38 capname="perfmon"
    [ 90.735553] audit: type=1400 audit(1719388676.652:159): apparmor="DENIED" operation="open" class="file" profile="snap-update-ns.snapd-desktop-integration" name="/proc/1767/maps" pid=1767 comm="5" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
    [ 106.088668] audit: type=1326 audit(1719388691.962:160): auid=1000 uid=1000 gid=1000 ses=1 subj=snap.snapd-desktop-integration.snapd-desktop-integration pid=1799 comm="snapd-desktop-i" exe="/snap/snapd-desktop-integration/157/usr/bin/snapd-desktop-integration" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7bc2ae338531 code=0x50000
    [ 106.088711] audit: type=1326 audit(1719388691.962:161): auid=1000 uid=1000 gid=1000 ses=1 subj=snap.snapd-desktop-integration.snapd-desktop-integration pid=1799 comm="snapd-desktop-i" exe="/snap/snapd-desktop-integration/157/usr/bin/snapd-desktop-integration" sig=0 arch=c000003e syscall=141 compat=0 ip=0x7bc2ae3b778b code=0x50000
    [ 106.343526] audit: type=1326 audit(1719388692.217:162): auid=1000 uid=1000 gid=1000 ses=1 subj=snap.snapd-desktop-integration.snapd-desktop-integration pid=1799 comm="snapd-desktop-i" exe="/snap/snapd-desktop-integration/157/usr/bin/snapd-desktop-integration" sig=0 arch=c000003e syscall=203 compat=0 ip=0x7bc2ae338531 code=0x50000
    [ 106.343549] audit: type=1326 audit(1719388692.217:163): auid=1000 uid=1000 gid=1000 ses=1 subj=snap.snapd-desktop-integration.snapd-desktop-integration pid=1799 comm="snapd-desktop-i" exe="/snap/snapd-desktop-integration/157/usr/bin/snapd-desktop-integration" sig=0 arch=c000003e syscall=141 compat=0 ip=0x7bc2ae3b778b code=0x50000
    dusan@S760:~$
asdf
#49 Příspěvek od asdf »
Když ony v tom ovladači nejsou žádné kontrolní výpisy, tak toho asi moc neuvidíme. Leda si tam nějaké přidat.
Duvsan
#50 Příspěvek od Duvsan »
Nemali sme použiť dobové jadro?
asdf
#51 Příspěvek od asdf »
To by asi neprošel překlad.
matahari
#52 Příspěvek od matahari »
Tahle hláška (včetně všech dalších bez zakomentování)
Kód: Vybrat vše
Skipping BTF generation for /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko due to unavailability of vmlinux
jde zrušit
Kód: Vybrat vše
apt install dwarves
cp /sys/kernel/btf/vmlinux /usr/lib/modules/`uname -r`/build/
asdf
#53 Příspěvek od asdf »
Asi máme blbě ještě jednu věc - ta proměnná CONFIG_MOUSE_PS2_FUJITSU_SCROLL se nepropíše do toho překladu pomocí CC.
Do fujitsu_scroll.h bych přidal řádek:
Kód: Vybrat vše
#define CONFIG_MOUSE_PS2_FUJITSU_SCROLL
Takže to pak bude začínat nějak takhle:
Kód: Vybrat vše
/* SPDX-License-Identifier: GPL-2.0-only */
 * Fujitsu Scroll device PS/2 mouse driver
#ifndef _FUJITSU_SCROLL_H
#define _FUJITSU_SCROLL_H
#ifdef CONFIG_MOUSE_PS2_FUJITSU_SCROLL
#define FJS_RANGE        0x01000
 * The maximum possible range that can be reported
#define FJS_MAX_POS (FJS_RANGE - 1)
Pak znova přeložit (make -C ...), zkomprimovat pomocí zstd, nahrát do /usr/lib/... a restartovat.
Duvsan
#54 Příspěvek od Duvsan »
matahari, stalo sa.
asdf. preklad prebehol.
    root@S760:/home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse# make -C /usr/src/linux-headers-6.8.0-35-generic/ M=$PWD
    make: Entering directory '/usr/src/linux-headers-6.8.0-35-generic'
    warning: the compiler differs from the one used to build the kernel
    The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0
    You are using: gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0
    CC [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse-base.o
    CC [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/fujitsu_scroll.o
    /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/fujitsu_scroll.c:84:6: warning: no previous prototype for ‘fujitsu_scroll_init_sequence’ [-Wmissing-prototypes]
    84 | void fujitsu_scroll_init_sequence(struct psmouse *psmouse)
    /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/fujitsu_scroll.c:95:5: warning: no previous prototype for ‘fujitsu_scroll_query_hardware’ [-Wmissing-prototypes]
    95 | int fujitsu_scroll_query_hardware(struct psmouse *psmouse)
    LD [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.o
    MODPOST /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/Module.symvers
    CC [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.mod.o
    LD [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko
    BTF [M] /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko
    make: Leaving directory '/usr/src/linux-headers-6.8.0-35-generic'
I kompilácia.
    zstd: psmouse.ko.zst already exists; overwrite (y/n) ? y
    psmouse.ko : 25.39% ( 4.35 MiB => 1.10 MiB, psmouse.ko.zst)
A u nás prší.
Čáry-máry so súbormi.
    root@S760:/home/dusan# cd /usr/lib/modules/6.8.0-35-generic/kernel/driver/input/mouse/
    sudo mv psmouse.ko.zst psmouse.ko.zst.orig
    sudo cp /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko.zst .
    ls -l
    bash: cd: /usr/lib/modules/6.8.0-35-generic/kernel/driver/input/mouse/: Adresár alebo súbor neexistuje
    mv: nie je možné stat() 'psmouse.ko.zst': Adresár alebo súbor neexistuje
    celkom 227436
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Desktop
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Documents
    drwxr-xr-x 3 dusan dusan 4096 jún 25 00:06 Downloads
    drwxr-xr-x 30 root root 4096 jún 25 15:32 linux-6.8.0
    -rw-r--r-- 1 root root 230060117 mar 15 16:29 linux_6.8.0.orig.tar.gz
    -rw-r--r-- 1 root root 1616761 máj 23 22:58 linux_6.8.0-35.35.diff.gz
    -rw-r--r-- 1 root root 9267 máj 23 22:58 linux_6.8.0-35.35.dsc
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Music
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Pictures
    -rw-r--r-- 1 root root 1157896 jún 26 16:24 psmouse.ko.zst
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Public
    drwx------ 5 dusan dusan 4096 jún 25 00:00 snap
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Templates
    drwxr-xr-x 2 dusan dusan 4096 jún 24 21:38 Videos
asdf
#55 Příspěvek od asdf »
Překlad vypadá OK.
To čáry máry musíš asi dávat po jedné řádce.
A tentokrát bych místo mv dal rm, abychom si nepřepsali ten úplně původní soubor. Takhle.
Kód: Vybrat vše
sudo rm psmouse.ko.zst
ls -l
Duvsan
#56 Příspěvek od Duvsan »
Dodatočne som si uvedomil. Prší u nás, fúkalo, vypadol internet, nemohol som opraviť. BTW, mali sme ľadovec. Padali kúsky väčšie ako fazuľa. Skôr polka palca. Oplatí sa viesť záhradku. Ach.
Idem na to.
A v prvom riadku má byť nie driver, ale drivers. To ma zachránilo pred prepísaním origo súboru psmouse.
A práve som to urobil. Chvíľka nepozornosti. Mám otvorených viac okien. Asi sa nepýta, či môže nahradiť pôvodný súbor novým s rovnakým menom. Dá sa to vrátiť? Ďalšie kroky nerobím.
asdf píše:Dej:
Kód: Vybrat vše
Naposledy upravil(a) Duvsan dne 26 čer 2024, 17:05, celkem upraveno 1 x.
asdf
#57 Příspěvek od asdf »
Aha, to jsem asi popletl.
U nás je krásně. Svítí sluníčko.
asdf
#58 Příspěvek od asdf »
To nevadí. On ten nový ovladač funguje, tak tam klidně může zůstat. A při dalším updatu kernelu se ti to stejně předělá na originální ovladač.
Duvsan
#59 Příspěvek od Duvsan »
Tak idem ďalej.
    root@S760:/usr/lib/modules/6.8.0-35-generic/kernel/drivers/input/mouse# sudo cp /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko.zst
    cp: chýba operand cieľového súboru po '/home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko.zst'
    Try 'cp --help' for more information.
Tak ináč.
    root@S760:/usr/lib/modules/6.8.0-35-generic/kernel/drivers/input/mouse# sudo cp /home/dusan/Downloads/fujitsu_scroll-main/drivers/input/mouse/psmouse.ko.zst .
    ls -l
    celkom 2324
    -rw-r--r-- 1 root root 12192 máj 20 16:26 appletouch.ko.zst
    -rw-r--r-- 1 root root 9334 máj 20 16:26 bcm5974.ko.zst
    -rw-r--r-- 1 root root 35803 máj 20 16:26 cyapatp.ko.zst
    -rw-r--r-- 1 root root 21769 máj 20 16:26 elan_i2c.ko.zst
    -rw-r--r-- 1 root root 3808 máj 20 16:26 gpio_mouse.ko.zst
    -rw-r--r-- 1 root root 1157896 jún 26 17:16 psmouse.ko.zst
    -rw-r--r-- 1 root root 1094067 jún 25 21:52 psmouse.ko.zst.orig
    -rw-r--r-- 1 root root 4824 máj 20 16:26 sermouse.ko.zst
    -rw-r--r-- 1 root root 7136 máj 20 16:26 synaptics_i2c.ko.zst
    -rw-r--r-- 1 root root 7448 máj 20 16:26 synaptics_usb.ko.zst
    -rw-r--r-- 1 root root 6002 máj 20 16:26 vsxxxaa.ko.zst
asdf
#60 Příspěvek od asdf »
To vypadá dobře. A teď restart. A uvidíme.
Zpět na „Výpočetní technika“
