Mám kameru sony DCR-TRV30E a asi po 5 letech používání se na displei při focení začalo oběvovat chybové hlášení E:91:01 a nenabije se blesk. Část "kamera" pracuje perfektně ale při focení nejde fotit zbleskem.
Nemáte prosím někdo zkušenost s tímto hlášením ? Děkuji za odpovědí
Some cameras have a RESET button built into them or a menu option to reset the camera to the default settings. The manuals of some camera models may have instructions on how to initialize the camera, which is another name for resetting the camera to the default or original factory settings. Refer to the instruction manual supplied with your camera for specific information regarding the availability of a RESET button or menu option to initialize or reset the default settings. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
Otherwise, continue with the manual reset procedure below:
1. Turn off the camera.
2. Ensure the camera is not connected to an AC power adapter.
3. Remove the battery from the camera for 15 seconds.
4. Reinsert the battery.
5. Turn on the camera.
