Chybové kódy u notebooku
Přes F8 a nový restart, který nařídí, W 98 nabehne a funguje OK. Je to IBM Thinkpad 600E.
Kdo by mohl zveřejnit tabulku chybových hlášení, dopředu děkuji.
kódy
101 Interrupt failure.
102 Timer failure.
103 Timer interrupt failure.
104 Protected mode failure.
105 Last 8042 command not accepted.
107 NMI test failure.
108 Timer bus test failure.
109 Low meg-chip select test.
110 Planar parity.
111 I/O parity.
118 Planar parity error logged.
158 A supervisor password is set, but no hard disk password is set.
159 The hard disk password is not identical to the supervisor password.
161 Dead battery.
163 Date and time are not set; clock not updated.
173 CMOS CRC error.
174 Configuration error.
175 Bad EEPROM CRC 1.
177 Bad supervisor password checksum.
178 EEPROM is not functional.
179 NVRAM error log full.
183 Supervisor password is needed.
184 Bad power-on password checksum.
185 Corrupted startup boot sequence.
186 Inconsistency between EEPROM and security lock latch 2.
188 Bad EEPROM CRC 2.
189 Too many passwords attempted.
190 Critically low battery condition detected.
191 XX PM initialization error. ( X can be any character.)
195 Configuration mismatch error found during hibernation wake-up.
196 Critical error found during hibernation wake-up.
201 Memory data error.
202 Memory line error 00 through 15.
203 Memory line error 16 through 23.
215 Memory test failure on on-board memory.
221 ROM to RAM remap error.
301 Keyboard error.
601 Diskette drive or controller error.
602 No valid boot record on diskette.
604 Invalid diskette drive error.
1101 Serial-A test failure.
1201 Serial-B test failure.
1701 Hard disk controller failure.
1780, 1790 Hard disk 0 error.
1781, 1791 Hard disk 1 error.
2401 System board video error.
8081 PCMCIA presence test failure (PCMCIA revision number also checked).
8082 PCMCIA register test failure.
8601 System bus error (8042 mouse interface).
8602 External mouse error.
8603 System bus error or mouse error.
8611 System bus error (I/F between 8042 and IPDC).
8612 TrackPoint III error.
8613 System board or TrackPoint III error.
I9990301 Hard disk error.
I9990302 Invalid hard disk boot record.
I9990303 Bank-2 flash ROM checksum error.
I9990305 No bootable device.
- vladimirek
Návštěvník
- tominekk
- Kontaktovat uživatele:
Vcelku se i líbílo jak autor položil dotaz a následně si na něj odpověděl
Nechci aby jste to vzal špatně je to jen můj postřeh.
A pro tu baterku:
Najít si info o tom notesu na netu nebo zavolat do nějakého PC servisu a poptat se. Pokud budou normální zcela jistě odpoví.
A nebo ho otevřít a sám se přesvědčit.
