pred nejakym casom mi zacala svietit kontrolka motora. Diagnostika hovori ze problem s nasavacimi klapkami..ma to dve "banky" - to su take plastove "krabice" kadial kazda 3-jica valcov nasava vzduch, a kazdy valec ma jednen priamy otvor na nasavanie vzduchu a klapku - tie klapky su teda 3 na jednej osi - a osou otaca taky elektromotorcek s riadenim, teda vsetko 2x - dve banky, 2 motorceky (pre kazdu trojicu valcov jeden)
napisem co som doteraz skontroloval/vymenil.. Zrepasoval samotne klapky - trojica plastovych klapiek + tiahlo ku motorceku... stare boli zadrbane a mali uz hodne velku volu, opravovacou sadou, jeden motorcek netahal za tiaholo a diagnostika davala 2 chyby:
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 4F0 910 401 A HW: 4F0 907 401 B
Component and/or Version: 3.0L V6TDI 000AG 0020
Software Coding: 0011372
Work Shop Code: WSC 02334 785 00200
VCID: 1A31CCB1D584989
2 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 171693 km
Time Indication: 0
Date: 2014.02.13
Time: 20:12:03
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
Duty Cycle: 20.5 %
005445 - Throttle Valve Controller
P1545 - 002 - Malfunction
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 171693 km
Time Indication: 0
Date: 2014.02.13
Time: 20:12:04
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Voltage: 11.93 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
a ked som vymenil este aj ten vadny motorcek tak vsetko napohlad funguje ako ma, po zosliapnuti plynu obe klapky idu synchronne (otvaraju privod vzduchu)
ale po zmazani chyby diagnostikou sa po vyhaseni motora a znova nastartovani znova objavi chyba (zase sa zasvieti kontrola motora), teraz uz len jedna - ta prva - (Lower Stop not Reached) sa uz neobjavuje ale ostala ta druha... zo zvedavosti som otvoril tu vadnu klapku, a bol tam zhoreny 12Vtovy jednosmerny motorcek od firmy Johnson (cely vyrobok je VDO)... Ak by mal niekto ideu preco tam ostala este ta druha chybka, resp. co tej prekliatej elektronike este vadi
