Grundig -jak z hotel mode
neznáte někdo jak se dostat na odblokování hotelmode z výše uvedené TV.
Grundig P37-050
CUC5303
1.Switch off tv set with main power switch.
2.Depress and hold the button P/C on the remote control while switching
on with the mains button(hold until appear service mode)
3.In service menu set volume to max value and press OK.
4.If you need can also set OSD position and press OK.
5."i" for exit.
Child lock cancel : VOL+,VOL-,PR-,PR+,OK.
Možná to bude stejné,ale nevím.
