Jak prověřit dostatečný ADSL signál
Sem patří samozřejmě i přístroje s "utrženým sluchátkem"- bezdrátové, ale vždy dále s okolním světem komunikující po vedení, a to nejen ve veřejných sítích.
Pro telefony GSM a podobné máme samostatnou sekci.
Zmije
#31 Příspěvek od Zmije »
Jo kdyby v 94. do země místo mědi dali optiku, bylo by to dnes jiný kafe.
Myslím, že to na 1600m od ústředny není špatný:
Kód: Vybrat vše
noise margin upstream: 21 db
output power downstream: 15 db
attenuation upstream: 15 db
attainable rate upstream: 1116 kbps
SATN upstream: 15 db
carrier load: number of bits per symbol(tone)
tone   0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45
tone  32- 63: 55 66 66 77 77 76 66 66 66 55 44 43 32 00 00 00
tone  64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone  96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 18 db
output power upstream: 12 db
attenuation downstream: 27 db
attainable rate downstream: 16364 kbps
SATN downstream: 24 db
tone   0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone  32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone  64- 95: 00 02 22 35 36 65 67 66 77 87 87 74 77 77 78 87
tone  96-127: 68 88 87 88 67 77 88 77 88 87 88 80 87 68 88 87
tone 128-159: 87 78 78 78 77 77 76 77 76 66 87 86 66 77 77 67
tone 160-191: 76 76 66 57 77 77 76 77 76 77 77 67 77 77 77 77
tone 192-223: 76 77 76 66 66 55 66 62 66 75 66 66 56 66 66 66
tone 224-255: 66 66 66 66 66 56 65 65 56 66 65 64 66 66 66 65
tone 256-287: 66 66 65 56 46 66 66 65 65 66 56 65 45 56 65 55
tone 288-319: 65 45 56 54 66 55 63 56 65 65 66 55 65 65 56 55
tone 320-351: 56 56 65 55 66 45 65 66 56 65 65 65 54 55 55 55
tone 352-383: 55 55 56 66 56 66 55 65 55 54 55 54 45 54 55 54
tone 384-415: 55 55 55 55 55 45 55 55 54 55 44 44 45 54 44 55
tone 416-447: 44 44 44 34 44 43 44 44 44 44 44 42 44 44 42 24
tone 448-479: 24 22 22 22 22 42 22 32 22 22 22 22 22 22 22 22
tone 480-511: 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 20
honzasl
#32 Příspěvek od honzasl »
Oživím staré téma:
Když byla řeč o znovupoužívání starých kabelů:
Do domu nám vedou vedou dvě telefonní přípojky: nová s tenkými vodiči a stará s tlustými (tipnul bych 0,25mm2). Nová vede odkudsi z ulice, stará přípojka vede po zahradě. Při práci na zahradě jsem objevil, že dříve, když starý rozvod fungoval, stál mezi námi a sousedem dřevený sloupek a na něm kovová rozbočovací skřínka (vede odsud tlustý kabel do ústředny a kabely k domům v okolí) Když se udělaly nové rozvody, sloupek skáceli a kabely se skřínkou na konci schovali pod drn, prostě mělko pod trávník.
A teď se ptám: mám se k těm starým kabelům chovat jako k aktivnímu telefonnímu vedení, nebo jako ke starému šrotu v zahradě, který je dávno odepsaný? Jde mi o to, jestli když se rozhodnu postavit v místě těch kabelů garáž, aby mi Telefonica v rámci stavebního řízení neposlala vyjádření, že na pozemku má kabely a musím zřídit jejich přeložku (byť jsou to staré káble).
lopez
#33 Příspěvek od lopez »
Chcem poprosit o radu.
Mam D-Link 2641R a problem s rozpadom spojenia.Rozpad spojenia nastava aj s routrom Zyxel aj Edimax.Tak ze v zariadeni problem nebude.Diagnostika a kontrolka signalizuje ze DSL je synchronizovana -teda OK.K comu sa to vlastne nemoze pripojit? Neustale tam telefonujem a nahlasujem tento problem.Oni potom nieco restartuju a potom to "ide".Co? alebo ako sa vola to co restartuju? -co je vlastne na hovno? ked tento problem trva viac ako rok a nevedia (alebo nechcu) ho odstranit?
Este dodam ze DSL mam asi 8 rokov a ziadny problem som nemal -len posledny rok to vypadava kazdy tyzden.Este dodavam vypis routra a silu signalu.
D-Link 2641R
Downstream Upstream
Rate (Kbps): 5760 kbps 573 kbps
SNR Margin (dB): 14.0 24.3
Attenuation (dB): 21.0 13.3
Output Power (dBm): 0.0 13.3
KONTROLA SYSTÉMU
Test ethernetového (1-4) pripojenia: OK
Test ADSL synchronizácie: OK
TEST INTERNETOVEJ KONEKTIVITY
Test priradenej adresy IP: CHYBA
Ping na východiskovú bránu ISP: CHYBA
Ping na uprednostnovaný server DNS: CHYBA
EDIMAX
DOWN UP
SNR Margin 16 18.0 db
Line Attenuation 25.0 12.0 db
Rýchlost downstreamu : 5760 kbps
Rýchlost upstreamu : 573 kbps
lopez
#34 Příspěvek od lopez »
Este dodam ze som bol pocas vypadku u suseda o poschodie vyssie a jemu to slo bez problemov.On ani ziadne vypadky nezaznamenal.Ako je toto mozne?.
Zpět na „Linkové telefony, faxy, tel. ústředny včetně domácích“
