Bateria Apple A1185 (bq20z80) - nejde vymazat PFStatus
#1 Příspěvek od rnbw »
Mam tu stary MacBook (2007) s bateriou A1185. Nejde nabijat. Rozobrat sa da pekne. Je tam bq20z80 a li-pol clanky zapojene ako 3S2P. Nafuknute nie su, akurat boli vybite (pod 2V) a rozvazene. Zrovnal som ich na 2,8V (dlhsie sa mi cakat nechcelo).
Pripojil som smbusb ( http://www.karosium.com/p/smbusb.html ). Najprv to nekomunikovalo, ale stacilo pripojit na moment 12V na konektor baterie (+ a -) a bq20z80 ozil:
Kód: Vybrat vše
# ./smbusb_sbsreport
SMBusb Firmware Version: 1.0.1
Manufacturer Name:          DP
Device Name:                ASMB013
Device Chemistry:           LION
Serial Number:              30972
Manufacture Date:           2007.04.01
Manufacturer Access:        8061
Remaining Capacity Alarm:   300 mAh(/10mWh)
Remaining Time Alarm:       10 min
Battery Mode:               0001
At Rate:                    0 mAh(/10mWh)
At Rate Time To Full:       65535 min
At Rate Time To Empty:      65535 min
At Rate OK:                 1
Temperature:                24.25 degC
Voltage:                    8075 mV
Current:                    0 mA
Average Current:            0 mA
Max Error:                  1 %
Relative State Of Charge    0 %
Absolute State Of Charge    0 %
Remaining Capacity:         0 mAh(/10mWh)
Full Charge Capacity:       660 mAh(/10mWh)
Run Time To Empty:          65535 min
Average Time To Empty:      65535 min
Average Time To Full:       65535 min
Charging Current:           0 mA
Charging Voltage:           0 mV
Battery Status:             4ad0
Cycle Count:                561
Design Capacity:            5020 mAh(/10mWh)
Design Voltage:             10950 mV
Specification Info:         0031
Cell 0 voltage:             7946 mV
Cell 1 voltage:             2 mV
Cell 2 voltage:             3 mV
Cell 3 voltage:             513 mV
Tu je pekny clanok o podobnej baterii (dokonca aj kluce sedia), akurat pouziva iny pristup k smbus (Arduino): https://squidgeefish.com/projects/a1175 ... cking.html
Unseal - funguje (bit 13 vynulovany):
Kód: Vybrat vše
# ./smbusb_comm -a 16 -c 0x00 -w 0414 && ./smbusb_comm -a 16 -c 0x00 -w 3672
# ./smbusb_comm -a 16 -c 0x54 -r 2
c061
PF Status = 4030 (PFVSHUT | CFETF | CIM)
Kód: Vybrat vše
# ./smbusb_comm -a 16 -c 0x53 -r 2
4030
Full access mode - funguje (bit 14 sa vynuloval - c061->8061):
Kód: Vybrat vše
# ./smbusb_comm -a 16 -c 0x00 -w ffff && ./smbusb_comm -a 16 -c 0x00 -w ffff
8061
Precitanie PF Key, Unseal Key a Full Access Key:
Kód: Vybrat vše
# ./smbusb_comm -a 16 -c 0x62 -r 4
73261217
# ./smbusb_comm -a 16 -c 0x60 -r 4
14047236
# ./smbusb_comm -a 16 -c 0x61 -r 4
ffffffff
Lenze po zadani Permanent Fail Clear sa nic nedeje, PFStatus sa nezmazal:
Kód: Vybrat vše
# ./smbusb_comm -a 16 -c 0x00 -w 2673 && ./smbusb_comm -a 16 -c 0x00 -w 1712
4030
Mam nabit clanky viac alebo sa mu nepaci este nieco ine?
#2 Příspěvek od rnbw »
Dorovnal som clanky do 3,0V a potom to preslo:
Kód: Vybrat vše
0000
Bateria uz ide nabijat :)
#3 Příspěvek od rnbw »
Umiestnenie CMOS (PRAM) baterie na spodok zakladnej dosky je na nobelovu cenu. Pri cene celeho toho kramu tam mohli kludne dat nabijaciu lithiovu a nie BR2325.
