životnost ložisek větráku
Kód: Vybrat vše
# smartctl -a /dev/sda -d megaraid,0
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.0-43-amd64] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: FUJITSU
Product: MAX3073RC
Revision: D207
User Capacity: 73,407,820,800 bytes [73.4 GB]
Logical block size: 512 bytes
Rotation Rate: 15000 rpm
Logical Unit id:
Serial number:
Device type: disk
Transport protocol: SAS (SPL-4)
Local Time is: Tue Mar 10 17:44:04 2026 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
Temperature Warning: Disabled or Not Supported
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 22 C
Drive Trip Temperature: 65 C
Accumulated power on time, hours:minutes 162689:06
Manufactured in week 26 of year 2007
Specified cycle count over device lifetime: 10000
Accumulated start-stop cycles: 26
Elements in grown defect list: 0
Error counter log:
Errors Corrected by Total Correction Gigabytes Total
ECC rereads/ errors algorithm processed uncorrected
fast | delayed rewrites corrected invocations [10^9 bytes] errors
read: 0 15475 0 0 0 234483.658 0
write: 0 15905 0 0 0 334320.830 0
verify: 0 4607 0 0 0 71059.536 0Az na jeden server plny SSD, kde po vypnuti umreli vsetky jedneho typu - bug vo firmware po prekroceni 32768 hodin. Utilita na upgrade FW s radicom nefungovala. Musel som ich vybrat a upgradovat rucne po jednom v inom PC.
Ventilatory v serveroch byvaju po rokoch hlucne, ale vacsinou sa to neriesi, pretoze v serverovni je hluk. Pokym sa lozisko nerozsype.
