PIC16F627 nefunguje
seeter
PIC16F627 nefunguje
seeter
schema.jpg- (14.12 KiB) Staženo 111 x
- One.ASM
- (1.13 KiB) Staženo 123 x
Kód: Vybrat vše
list p=16F627 ; list directive to define processor
#include <P16f627.inc> ; processor specific variable definitions
errorlevel -302
__CONFIG _CP_OFF & _DATA_CP_OFF & _LVP_OFF & _BODEN_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _HS_OSC
;--------- CONSTANTS DEFINITIONS---------------------------------------
#define RAM_Start 0x20
#define TIME0 D'30'
#define TIME1 D'30'
#define TIME2 D'30'
;--------- VARIABLE DEFINITIONS ---------------------------------------
CBLOCK RAM_Start
TMP0
TMP1
TMP2
ENDC
ORG 0x000 ; Processor reset vector
reset nop
goto init ; Go to beginning of program
ORG 0x004 ; interrupt vector location
nop
init
BSF STATUS,RP0
MOVLW B'00000000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
BCF STATUS,RP0
MOVLW TIME2
MOVWF TMP2
MOVLW TIME1
MOVWF TMP1
MOVLW TIME0
MOVWF TMP0
DECFSZ TMP0,F
GOTO $-1
DECFSZ TMP1,F
GOTO $-5
DECFSZ TMP2,F
GOTO $-9
FIRST MOVLW B'00000100'
MOVWF PORTB
MOVLW TIME2
MOVWF TMP2
MOVLW TIME1
MOVWF TMP1
MOVLW TIME0
MOVWF TMP0
DECFSZ TMP0,F
GOTO $-1
DECFSZ TMP1,F
GOTO $-5
DECFSZ TMP2,F
GOTO $-9
MOVLW B'00000000'
MOVWF PORTB
MOVLW TIME2
MOVWF TMP2
MOVLW TIME1
MOVWF TMP1
MOVLW TIME0
MOVWF TMP0
DECFSZ TMP0,F
GOTO $-1
DECFSZ TMP1,F
GOTO $-5
DECFSZ TMP2,F
GOTO $-9
GOTO FIRST
END Nebo ještě lépe takto:
Kód: Vybrat vše
errorlevel -302
#define TIME0 D'30'
#define TIME1 D'30'
#define TIME2 D'30'
CBLOCK RAM_Start
TMP0
TMP1
TMP2
ENDC
reset nop
nop
init
BSF STATUS,RP0
MOVLW B'00000000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
BCF STATUS,RP0
call delay
MOVWF PORTB
call delay
MOVLW B'00000000'
MOVWF PORTB
call delay
GOTO FIRST
delay
MOVLW TIME2
MOVWF TMP2
del2 MOVLW TIME1
MOVWF TMP1
del1 MOVLW TIME0
MOVWF TMP0
del0 DECFSZ TMP0,F
GOTO del0
DECFSZ TMP1,F
GOTO del1
DECFSZ TMP2,F
GOTO del2
return
END -
seeter
Kód: Vybrat vše
_DATA_CP_OFF - není definovaná Kód: Vybrat vše
ale po natažení do procesoru to pořád nefungujeJaký používáš krystal? Do 4MHz je vhodné použít _XT_OSC místo _HS_OSC v direktivě __CONFIG.
Kód: Vybrat vše
proč tam jsou na začátku programu příkazy pro přerušení První NOP na adrese 0x000 je rezervace pro ICD - In Circuit Debugging, tebe se to s emulátorem netýká, můžeš to vypustit. ORG 0x004 rezervuje prostor pro přerušení a na místo budoucího vektoru jsem vložil tu druhou NOP. Žádné přerušení v programu neexistuje ale brzo to budeš potřebovat.
Kód: Vybrat vše
proč tam jsou přidané proměnné jako TIME0,1 a 2To nejsou proměnné, nýbrž konstanty.Chtěl jsem ti prezentovat, že je naprosto zcestné používat přímo v programu číselné konstanty. Pokud bys chtěl v původním programu konstantu D'30' změnit, musel bys to dělat na třech místech. Ve složitějším programu je to jen zdrojem chyb.
Kód: Vybrat vše
errorlevel - 302 Kód: Vybrat vše
CBLOCK RAM_Start Předtím definovaná konstanta RAM_Start ukazuje na počátek použitelné RAM. Příkaz CBLOCK definuje počátek pole uživatelských promněných. Mezi CBLOK a ENDC píšeš svoje proměnné a nemusíš jim přiřazovat absolutní adresy třeba pomocí EQU, jak jsi to udělal ty.
Kód: Vybrat vše
co znamenájí ty definice v řádku Je to nastavení jednotlivých konfiguračních bitů procesoru. Jejich význam najdeš v datasheetu třeba pod pojmem configuration bits.
seeter
Kód: Vybrat vše
__CONFIG _LVP_OFF & _BODEN_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTRC_OSC_NOCLKOUTa uvidíš.
seeter
