Thomson 29 ICC17 EN
Thomson 29 ICC17 EN
Dekuji za napovedu.
Thomson TV Model: (ICC17 Chassis)
Standby led fault codes and meanings list / standby led flashes then pauses
Code meanings are as follows:
10 = child lock mode,
11 = timer mode,
14 = there is no response from Iv01,
15 = there is no response from IS40,
20 = bus access prohibited by software,
21 = bus data line held low,
23 = bus clock line held low,
25 = switched 5v supply missing,
26 = crt is not warming in the allotted time,
27 = deflection failure more than three times,
28 = IF01 guard voltage (pin exceeded,
34 = no response from the nvm chip IR03,
36 = incorrect address passed to bus handler,
37 = unexpected level on NMI line (power fail),
41 = bus data line not recoverable
PS : Ak budeš merať tie pozistory tak ten čo je medzi fazou a nulakom mamať cca 1,2 Kohm a ten na demag cievku cca 50ohm ale to zaleži od typu pozistoru.
http://uloz.to/265871/DSC00082.JPG
To je foto chassis foto zdroje. TV Thomson 29DF25 EG ICC17
Odezva pak jde i z VN na zdroj. 110 -130 volt. impulzuje. Uz 8 roku nedelam v servisu a tak jsem i neco zapomel a ted zacinaji problemi kdyz prijde novejsi novinka TV.
i VN trafo ven uplne a to se chova upne stejne,,, akorat se min otevre impulzni zdroj. A kdyz vickrat zmacknu PR + tak pak vylitne na to spravne napeti. Akorat vyblikava zavadu 27 Timer. i uz po vraceni trafa takze se jedna uz o jinou vadu. takze se ted budu zabivat vadou 27 codu.
Vada selhání odchylky víc než třikrát - co to je za vadu?
