ZDRAVÍM VŠECHNY.NEMÁTE NĚKDO SCHÉMA K TÉHLE TELEVIZI.OPAKOVANĚ MĚ PRORÁŽÍ BU 2525AF.ASI DO DVOU SEKUND.STAČIL JSEM SE JENOM PODÍVAT NA OBRAZ TEN SE JEVIL JAKO BY BYLA V HÁJI KOREKCE PODUŠKY.)(.MĚL JSEM VYPÁJENÉ SNAD VŠECHNY SOUČÁSTKY A TO I VE ZDROJI A KROM PÁR ELYTŮ KTERÉ KTERÉ JSEM MĚNIL VE ZDROJI JE VŠE VPOŘÁDKU.UŽ SE TADY NA FORU ŘEŠILO,ALE V PODSTATĚ BEZ NĚJAKÉHO ZÁVĚRU.BYL BYCH VDĚČEN ALESPON ZA TO SCHÉMA.POKUD SE TEDY NĚKDO S TÍMTO PROBLÉMEM U TÉTO TEL.JIŽ NESETKAL.ŠASI NA DESCE OZNAČENÉ NENÍ JE TAM 97TA021D A POD TÍMTO JSEM NIC NENAŠEL.DÍKY
