práce se strukturou
caven
práce se strukturou
#1 Příspěvek od caven »
Zravím, neporadil by mi někdo jak se s tímto pracuje ?
je to vytažené z codevision
Kód: Vybrat vše
// Timer/Counter 0
typedef struct TC0_struct
             unsigned char CTRLA; // Control Reg. A
             unsigned char CTRLB; // Control Reg. B
             unsigned char CTRLC; // Control Reg. C
             unsigned char CTRLD; // Control Reg. D
             unsigned char CTRLE; // Control Reg. E
             unsigned char reserved_0x05;
             unsigned char INTCTRLA; // Interrupt Control Reg. A
             unsigned char INTCTRLB; // Interrupt Control Reg. B
             unsigned char CTRLFCLR; // Control Reg. F Clear
             unsigned char CTRLFSET; // Control Reg. F Set
             unsigned char CTRLGCLR; // Control Reg. G Clear
             unsigned char CTRLGSET; // Control Reg. G Set
             unsigned char INTFLAGS; // Interrupt Flag Reg.
             unsigned char reserved_0x0D;
             unsigned char reserved_0x0E;
             unsigned char TEMP; // Temporary Reg. For 16bit Access
             unsigned char reserved_0x10;
             unsigned char reserved_0x11;
             unsigned char reserved_0x12;
             unsigned char reserved_0x13;
             unsigned char reserved_0x14;
             unsigned char reserved_0x15;
             unsigned char reserved_0x16;
             unsigned char reserved_0x17;
             unsigned char reserved_0x18;
             unsigned char reserved_0x19;
             unsigned char reserved_0x1A;
             unsigned char reserved_0x1B;
             unsigned char reserved_0x1C;
             unsigned char reserved_0x1D;
             unsigned char reserved_0x1E;
             unsigned char reserved_0x1F;
             WORDREG(CNT); // Count
             unsigned char reserved_0x22;
             unsigned char reserved_0x23;
             unsigned char reserved_0x24;
             unsigned char reserved_0x25;
             WORDREG(PER); // Period
             WORDREG(CCA); // Compare or Capture A
             WORDREG(CCB); // Compare or Capture B
             WORDREG(CCC); // Compare or Capture C
             WORDREG(CCD); // Compare or Capture D
             unsigned char reserved_0x30;
             unsigned char reserved_0x31;
             unsigned char reserved_0x32;
             unsigned char reserved_0x33;
             unsigned char reserved_0x34;
             unsigned char reserved_0x35;
             WORDREG(PERBUF); // Period Buffer
             WORDREG(CCABUF); // Compare Or Capture A Buffer
             WORDREG(CCBBUF); // Compare Or Capture B Buffer
             WORDREG(CCCBUF); // Compare Or Capture C Buffer
             WORDREG(CCDBUF); // Compare Or Capture D Buffer
} TC0_t;
Děkuji
