MSI K8T NEO2-FIR BIOS
- Peterseal
Ked dam F1-RUN SETUP, idem do BIOSU. Ked Zrestartujem PC tam mi pise : FOR ETHERNET CONTROLLER PXE-E61 Media test failure, check cable
PXE MOF- Exiting PXE ROM
Potom ked zapnem vypnem tak vstko nabehne, a mam na vyber iba BIOS FLASH....
Dosku som dostal bez baterky.
Treba to flsahnut?
Ako?
Peter
- vladimirek
- vladimirek
- Peterseal
Asi je dlbnuty BIOS...
Takze asi FLASH..
http://eu.msi.com/index.php?func=prodde ... rod_no=588
