TVP Mitsubishi CT-25AV1GD-S - servisní mód
press the service switch (s701, next to the aerial socket) and then button 9 within 5 seconds Press the * button to toggle between the VCJ or OPTION adjustment display. Press buttons 2 or 8 to increase or decrease the adjustment code number. Press buttons 6 or 4 to increase or decrease data value. After the adjustments, press 0 to write the adjustment data to the EEPROM.To cancel a change, press button 1 and all data adjusted since the last EEPROM write will be reset.TUN 0 Option settings for CT25AV1BS = SAT 1, AUD 10, ATS 1, STD 1, SYS 1, AV1 2, EEX -, SPK 1, EEP -, ABG 02, A1 02, AL 00, ADK 15, MNP 70, TXT -, FFT 1, VOL 74, HYP 1, SCP 20, FMP 23
akorát že místo s701 je natvrdo drátová propojka a rozpojení a spojení nefunguje...
