PROSIM O RADU. TV NESLA UZ SOM JU ROZCHODIL,ALE NIEKTO PREDOMNOU SA S NOU HRAL. PRED TRIMER NA ZDROJI PREDRADIL ODPOR TAKZE MI ZDROJ DAVAL NA HORIZONTAL IBA 100V. CELY PROBLEM BOL V ELYTOCH,TAKZE JU ROBIL PREDTYM AKYSI ODBORNIK. PANOVE NEVIETE KDE BY SA DALA ZOHNAT SCHEMA TOHTO TV,ALEBO AKE MA BYT NAPATIE NA HORIZONTAL. JA SOM ZATIAL NASTAVIL 105V ALE CHCEM MAT ISTOTU. TUTO TV VYRABALA PROGRESSON DUNAJSKA STREDA. NIKDE NEVIEM ZOHNAT SCHEMU. VO VNUTRI TO VYZERA AKO NEJAKE DAEWOO. MOC DIK ZA POMOC.
Skus sa poriadne pozriet na plosak.A ked vymenis elyti a odstranis ten pridany odpor,malo by to napatie byt niekde blizko skutocneho.mozno ti to pomoze,ale fakt len mozno
