[Android] Video návod s youtube
markoni
#1 Příspěvek od markoni »
Zase otravuji :D
Na https://www.youtube.com/watch?v=oPu42I0HSi4 je video návod a já "nemám co dělat" :D spíš hromadu času promarním než bych dělal něco užitečnějšího co je zas druhá věc takže mám nastaveno android 4.4 a dělám toto video krok za krokem teď jsem narazil na překážku v podobě video návodu který je pravděpodobně dělán na vyšší android protože mě to píše toto dá se s tím něco dělat kromě nastavení vyšší verze androidu (to bych nerad protože má telefon s androidem 4.4) nebo ne? díky
    Call requires API level 21 (current min is 17): android.hardware.camera2.CameraDevice#getId less... (Ctrl+F1)
    This check scans through all the Android API calls in the application and warns about any calls that are not available on all versions targeted by this application (according to its minimum SDK attribute in the manifest). If you really want to use this API and don't need to support older devices just set the minSdkVersion in your build.gradle or AndroidManifest.xml files. If your code is deliberately accessing newer APIs, and you have ensured (e.g. with conditional execution) that this code will only ever be called on a supported platform, then you can annotate your class or method with the @TargetApi annotation specifying the local minimum SDK to apply, such as @TargetApi(11), such that this check considers 11 rather than your manifest file's minimum SDK as the required API level. If you are deliberately setting android: attributes in style definitions, make sure you place this in a values-vNN folder in order to avoid running into runtime conflicts on certain devices where manufacturers have added custom attributes whose ids conflict with the new ones on later platforms. Similarly, you can use tools:targetApi="11" in an XML file to indicate that the element will only be inflated in an adequate context.
robo
#2 Příspěvek od robo »
Rekl bych ze nic. Mas API 17=Android 4.4 Je vyzadovano min API 21=Android verze 5. Takže preinstalovat na 5 android, ofic ci neofic rom. Kdyz nebude tak si muzes hledat jinou zabavu. :)
