TV SHARP nejde zapnout.
Pre servisný mód potrebuješ aj diaľkový ovládač, inak sa tam nedá potvrdiť voľba. Stiahni si servisný manuál, je to tam pekne popísané, aj čo a ako treba resetnúť pri výmene trubíc. "K" na displeji = si v servisnom režime. Z neho sa vychádza rovnako ako sa vchádza do servisného menu.
Servisný manuál, strana 3 - 24 píše:[11] Lamp error detection
1. Function description
This LCD colour television has a function (lamp error detection) to be turned OFF automatically for safety when the lamp or lamp circuit is abnormal
If the lamp or lamp circuit is abnormal, or some other errors happen, and the lamp error detection is executed, the following occur.
1- The main unit of television is turned OFF 5 seconds after itis turned ON. (The power LED on the front side of TV turns fromgreen to red.)
2 - If the situation “1” happens 5 times sequentially, the power is turned on (relay is turned ON).
However, the backlight is not turned on, and then the relay is turned OFF after 5 to 6 seconds. (The power LED turns from green to red.)
2. Countermeasures
When television is turned OFF by the lamperror detection mentioned above, it enters the adjustment process with the power LED red. Entering the
adjustment process turns OFF the error detection and turns ON TV. This enables the operation check to detect errors in the lampor lamp circuit
Check whether “L ERROR RESET” on point 7, page 10/11 of the adjustment process is 1 or more. If it is 1 or more, it indicates the lamp error detec-tion was executed. After confirming that the lamp or lamp circuit is normal, reset the lamp error counter pushing “OK” in the R/C. After resetting
counter the label “***OK***” appears on Screen.
3. Reset standby cause error list
After confirming that the lamp error counter has been erased, select “STAND BY CAUSE RESET” on point 3, page 10/11 of the adjustment process
and select ON using the right cursor. For execute press “OK” in the R/C and the label “***OK***” appears on Screen.
Ten obraz sa mi zdá normály, biela je po výmene trubíc snehobiela, omnoho krajšia ako na nových LED TV. Komu sa nepáči nech si dá normálny režim obrazu, a nie dynamický. Je to vec názoru.
Ja osobne nemám rád žiadny digitálny obraz. Aj v tom najlepšom vidím štvorcovú sieť, hlavne keď je záber na pohybujúcu sa zeleň. Analóg je analóg.
Vladik36 píše:Prosím jak do toho servisního modu.
- na opravu podsvícení nepotřebuješ servisní mód, podsvícení je čistě hardwarová záležitost
- až to opravíš, nastartuješ a televize půjde, opět nebudeš potřebovat vstup do servisního menu - fungující podsvícení nepotřebuje nic dostavovat
- jestli někdo usoudí, že už víš, co děláš, když vstoupíš do servisního menu, pošle ti to třeba soukromou zprávou. Tady se totiž přístupy do servisního menu nevyvěšují veřejně ani pro CRT televize, a těm už nějaký ten rok je, protože
- nejhůř se opravuje televize po někom, kdo to neumí, ale rozšteloval všechno, co se dalo, dřív, než odstranil příčinu,
- zvlášť, když servisní menu je v angličtině...
- z téhož důvodu to tu neusnadňujeme překladem i zveřejněných servisních manuálů
