Obaval som sa, ze nepojde v novsich Windows a ze bude problem so zvukom (podpora A2DP?). Vo Windows 7 funguje ako "Generic bluetooth adapter", ale druha obava sa naplnila - funguje len mono zvuk.
Jednoduche a lacne riesenie: kupit novy adapter.
A teraz sa mozem trochu pohrat s tym starym:
Kód: Vybrat vše
# hciconfig hci0
hci0: Type: Primary Bus: USB
BD Address: 00:0C:76:xx:yy:zz ACL MTU: 192:8 SCO MTU: 64:8
UP RUNNING
RX bytes:371 acl:0 sco:0 events:14 errors:0
TX bytes:290 acl:0 sco:0 commands:13 errors:0
# hciconfig hci0 features
Features: 0xff 0xff 0x0f 0x00 0x00 0x00 0x00 0x00
<3-slot packets> <5-slot packets> <encryption> <slot offset>
<timing accuracy> <role switch> <hold mode> <sniff mode>
<park state> <RSSI> <channel quality> <SCO link> <HV2 packets>
<HV3 packets> <u-law log> <A-law log> <CVSD> <paging scheme>
<power control> <transparent SCO>
# hciconfig hci0 version
HCI Version: 1.1 (0x1) Revision: 0x20d
LMP Version: 1.1 (0x1) Subversion: 0x20d
Manufacturer: Cambridge Silicon Radio (10)
# hciconfig hci0 revision
HCI 16.4
Chip version: BlueCore02-External
Max key size: 56 bit
SCO mapping: HCIFunguje DFU:
Kód: Vybrat vše
# dfu-util -l
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Deducing device DFU version from functional descriptor length
Found Runtime: [0db0:6970] ver=0525, devnum=7, cfg=1, intf=2, path="3-2", alt=0, name="UNKNOWN", serial="UNKNOWN"Vytiahneme firmware (funguje az na druhy raz):
Kód: Vybrat vše
# dfu-util -U backup.bin
dfu-util 0.9
Opening DFU capable USB device...
ID 0db0:6970
Run-time device DFU version 0100
Claiming USB DFU Runtime Interface...
Determining device status: state = appIDLE, status = 0
Device really in Runtime Mode, send DFU detach request...
Resetting USB...
dfu-util: Lost device after RESET?
dfu-util 0.9
ID 0db0:ffff
Determining device status: state = dfuIDLE, status = 0
dfu-util: WARNING: Runtime device already in DFU state ?!?
Claiming USB DFU Interface...
Setting Alternate Setting #0 ...
dfuIDLE, continuing
DFU mode device DFU version 0100
Device returned transfer size 1023
Copying data from DFU device to PC
Upload [=========================] 100% 354826 bytes
Upload done.Pozrieme do firmware:
Kód: Vybrat vše
# strings backup.bin | head -n 3
CSR-dfu2
LOADER=bc02x_hci_1v1_16.4_56, STACK=bc02x_hci_1v1_16.4_56
CSRbcfw1Je tam teda CSR BlueCore2-External BC212015 s firmwarom 0x20d (525), tzn. BT 1.1 s 56bit sifrovanim.
CSR vidiet aj na fotkach:
https://fccid.io/I4L-MS6970/Internal-Ph ... tos-314456
Flash je len 4Mbit (SST39VF400A v TFBGA).
Podla tohoto existuje firmware 0x632 (1586) s podorou BT 1.2:
https://web.archive.org/web/20080521215 ... h/csr.html
Potrebuje ale 8Mbit flash. Takze zozhnat SST39VF800A v TFBGA a vymenit. Nasledne cez SPI interface toho CSR naflashovat bootloader - to by som mal asi vyskusat ako prve. Otazne je, ci nahodou pre 8Mbit nie je potrebny iny bootloader... Potom by sa mal dat naflashovat firmware 1586 s podporou BT 1.2.
