Modul SIM800 řízený ESP32 CAM
markoni
#1 Příspěvek od markoni »
Mám takový projekt který v modulu kamery ESP32 CAM udělá obrázek a pošle ho pomocí modulu SIM800l na FTP server
Zdroják
Kód: Vybrat vše
#include "esp_camera.h"
// Pin definition for CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
camera_config_t config;
void setup() {
  Serial.begin(9600);
  initCamera();
  takePhoto();
  ATInternet();
void loop() {
  //takePhoto();
  //delay(10000);
void initCamera() {
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  if(psramFound()){
    config.frame_size = FRAMESIZE_XGA;//FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
    config.jpeg_quality = 10;
    config.fb_count = 2;
  } else {
    config.frame_size = FRAMESIZE_UXGA;
    config.jpeg_quality = 12;
    config.fb_count = 1;
  // Init Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
void takePhoto() {
 byte dat=0;
  camera_fb_t * fb = NULL;
  // Take Picture with Camera
  fb = esp_camera_fb_get();
  Serial.print("Velikost obrazu: ");
  Serial.print(fb->len);
  Serial.print(" B,");
  Serial.print((fb->len)/1024);
  Serial.println(" KB");
  Serial.print((fb->len) % 1024);
  //Serial.print("0x");
  /*for(int i=0;i<fb->len;i++)
     Serial.print(fb->buf[i], HEX);*/
Serial.println("");
//  dat = HEX(fb->buf);
  //Serial.write(fb->buf,fb->len);
  if(!fb) {
    Serial.println("Camera capture failed");
   while(fb->len){
//      dat=fb->buf,fb->len;
    //Serial.print(fb->buf,fb->len);
    return;
   * Free buffer cam
  esp_camera_fb_return(fb);
void ATInternet(){
  int poz=0;
  int dopocet=1024;
  String mesage="";
  delay(10000);
  Serial.print("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r");
  Serial.flush();
  delay(1000);
  while(Serial.available()){
    mesage=mesage+Serial.read();
  Serial.print("AT+SAPBR=3,1,\"APN\",\"internet\"\r");
  Serial.flush();
  delay(1000);
 Serial.print("AT+SAPBR=1,1\r");
 Serial.flush();
 delay(1000);
 Serial.print("AT+SAPBR=2,1\r");
 Serial.flush();
 delay(1000);
Serial.print("AT+FTPCID=1\r");
Serial.flush();
 delay(1000);
  Serial.print("AT+FTPSERV=\"***********\"\r");
  Serial.flush();
 delay(1000);
Serial.print("AT+FTPUN=\"*********\"\r");
Serial.flush();
  delay(1000);
Serial.print("AT+FTPPW=\"********\"\r");
Serial.flush();
delay(1000);
Serial.print("AT+FTPPUTPATH=\"/**************/\"\r");
Serial.flush();
delay(1000);
Serial.print("AT+FTPPUTNAME=\"picture.jpg\"\r");
Serial.flush();
delay(1000);
  Serial.print("AT+FTPPUT=1\r");
Serial.flush();
delay(3000);
  int c=(fb->len)/1024;
for(int l=0;l<=c;l++){
Serial.print("AT+FTPPUT=2,1024\r");
Serial.flush();
delay(3000);
  for(int i=0;i<=1024;i++)
     Serial.print(fb->buf[poz]);
     poz++;
  // put your setup code here, to run once:
delay(3000);
int z=(fb->len)%1024;
Serial.print("AT+FTPPUT=2,");
Serial.print(z);
Serial.print("\r");
Serial.flush();
 for(int i=0;i<=z;i++){
     poz++;
Serial.print("AT+FTPPUT=2,0\r");
Serial.flush();
někde mám chybu ale nevím kde ? o chybě kde tam chybí
AT+FTPTYPE=I
vím a doplním ale to pořád nevysvětluje že na FTP serveru jsou bloky ne malé stejných dat a to je špatně .Další chyba je že některé ty pakety se nepřenesou ale to je asi problém mobilního signálu to bych zatím neřešil .
Další věc ta kamera někdy alokuje větší prostor pro bufer na obrázek a a ten modul ESP32 CAM se resetuje tu část kódu taky jsem nedělal já taky by se někdo s této komunity mohl podívat jestli tam někde není chyba ? já vím že chci od vás mnoho ale nemohu si pomoc :?
díky moc za pomoc
edit přidávám ještě výpis na seriového monitoru to není ten samý seasion
soubor na ftp.txt
(49.11 KiB) Staženo 1205 x
seriový monitor.txt
(30.76 KiB) Staženo 1244 x
