LG 32lb561u
LG 32lb561u
robim vymenu posvitu na led tv LG
je tam driver SSC1S311 je mozna regulacia prudu??
robili ste to niekto ?
vdaka
http://j5d2v7d7.stackpathcdn.com/wp-con ... C1S311.pdf
Netvrdim,ze by sa nedal pouzit na podsvit.Ak ano pozri vyvod 6(OCP) a odtial odpory na gnd.
Burajko píše:A nebude to nahodou pohotovostny zdroj?
https://masterelectronicsrepair.blogspo ... b653v.html
https://elektrotanya.com/lg_eax65391401 ... ad.html#dl
tak ries odpory na q801 v sourci.A IC801 riadi prud cez LED..
Skontroluj aj `C802 a C803.
Zvyknu davat po nose ledkam...
edit: Je to tak :
You can reduce the backlight current in LG TVs with LGP32-14PL1 power supplies (EAX65391401) as follows. The current sensor consists of six resistors R816-R821 connected in parallel - 1 Ohm, 1 Ohm, 1 Ohm, 1 Ohm, 2 Ohm, 8.2 Ohm. The total resistance in this case will be 0.22 Ohm. If you remove one resistor 1 Ohm, the total resistance increases to 0.28 Ohm, the current decreases proportionally from 250 mA to about 190 mA.
