Co jste přinesli zajímavého ze sběrného dvora 5
RayeR
lesana87
RayeR
EDIT: Tak AI mi tvrdi, ze je tam naka podivna Socka: SMSC UFX6000
.How It Works Without a CPU Core
In a traditional thin client, a low-power CPU (like an ARM Cortex or Intel Atom) boots a lightweight Linux or Windows IoT operating system to connect to a network.
In contrast, the Atrust MD100 is a "zero client" because the SMSC UFX6000 hardware simply acts as a remote pipeline. The host server's CPU does 100% of the processing work. The server compresses the desktop screen into data packets and streams them over the network. The UFX6000 chip receives these packets via its USB/LAN controller and translates them straight into a video signal for your monitor.
Aha, takze este horsi jak ARMovy pocitac, ono to jen preposila USB a video pakety na server, ktery dela veskerou praci, nema to vlastni vypocatni jadro a RAM, je to zadratovane v tom cipu, cili kram celkem k hounu...
https://ww1.microchip.com/downloads/en/ ... c/6000.pdf
RayeR
https://www.atrustcorp.com/products/zero-client/
Okrem toho UFX6000 sa tam spomina nieco od Elite Silicon Technology. Tato firma robi SoC pre USB-LAN. Takze to asi cele funguje ako sietovy USB hub, do ktoreho je pripojena USB zvukovka, grafika a dalsie porty pre periferie.
RayeR
RayeR
lojzmen
RayeR
RayeR
EDIT" tak funguje, jen bylo potreba znovu preladit DAB stanice, tak uz jedou vsechny. Koukam vetsina radii mimo CRo jede jen 48kbps, to je teda kvalita...
judeware
