ESP32 WifiManager
markoni
ESP32 WifiManager
#1 Příspěvek od markoni »
Zdravím
Já jsem už možná tím otravný ale nemohu si pomoc.Nejde mi na ESP32 potažmo ESP32 CAM rozjet WifiManager ,na ESP8266 mi to funguje v pohodě kde dělám chybu? díky
Kód: Vybrat vše
#if defined(ESP8266)
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
#else
#include <WiFi.h>          //https://github.com/esp8266/Arduino
#endif
//needed for library
#include <ESP8266WebServer.h>
#else
#include <WebServer.h>
#endif
#include <DNSServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
// select which pin will trigger the configuration portal when set to LOW
// ESP-01 users please note: the only pins available (0 and 2), are shared
// with the bootloader, so always set them HIGH at power-up
#define TRIGGER_PIN 0
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  Serial.println("\n Starting");
  pinMode(TRIGGER_PIN, INPUT);
void loop() {
  // is configuration portal requested?
  if ( digitalRead(TRIGGER_PIN) == LOW ) {
    //WiFiManager
    //Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wifiManager;
    //reset settings - for testing
    //wifiManager.resetSettings();
    //sets timeout until configuration portal gets turned off
    //useful to make it all retry or go to sleep
    //in seconds
    //wifiManager.setTimeout(120);
    //it starts an access point with the specified name
    //here  "AutoConnectAP"
    //and goes into a blocking loop awaiting configuration
    //WITHOUT THIS THE AP DOES NOT SEEM TO WORK PROPERLY WITH SDK 1.5 , update to at least 1.5.1
    //WiFi.mode(WIFI_STA);
    if (!wifiManager.startConfigPortal("OnDemandAP")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      //reset and try again, or maybe put it to deep sleep
      ESP.restart();
      delay(5000);
    //if you get here you have connected to the WiFi
    Serial.println("connected...yeey :)");
  // put your main code here, to run repeatedly:
výstup na sériovém monitoru
Kód: Vybrat vše
3:10:58.664 -> ets Jun  8 2016 00:22:57
13:10:58.664 ->
13:10:58.664 -> rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
13:10:58.664 -> configsip: 0, SPIWP:0xee
13:10:58.664 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
13:10:58.664 -> mode:DIO, clock div:1
13:10:58.664 -> load:0x3fff0018,len:4
13:10:58.664 -> load:0x3fff001c,len:1216
13:10:58.664 -> ho 0 tail 12 room 4
13:10:58.664 -> load:0x40078000,len:9720
13:10:58.664 -> load:0x40080400,len:6352
13:10:58.664 -> entry 0x400806b8
13:10:58.965 ->
13:10:58.965 ->  Starting
13:11:06.587 -> *WM: SET AP STA
13:11:06.634 -> *WM:
13:11:06.634 -> *WM: Configuring access point...
13:11:06.634 -> *WM: OnDemandAP
13:11:07.088 -> *WM: AP IP address:
13:11:07.135 -> *WM: 192.168.4.1
13:11:07.135 -> *WM: HTTP server started
13:11:51.160 -> dhcps: send_offer>>udp_sendto result 0
13:11:52.263 -> *WM: Request redirected to captive portal
13:11:52.517 -> *WM: Handle root
13:11:52.517 -> Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
13:11:52.517 -> Core 1 register dump:
13:11:52.517 -> PC      : 0x400014fd  PS      : 0x00060230  A0      : 0x800da8fb  A1      : 0x3ffb1ce0
13:11:52.517 -> A2      : 0x00000020  A3      : 0x0000001c  A4      : 0x000000ff  A5      : 0x0000ff00
13:11:52.564 -> A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x00000000  A9      : 0x3ffb1c40
13:11:52.564 -> A10     : 0x3ffb1d00  A11     : 0x80000000  A12     : 0x3ffb1d00  A13     : 0x0000ff00
13:11:52.564 -> A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
13:11:52.564 -> EXCVADDR: 0x00000020  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xffffffff
13:11:52.564 ->
13:11:52.564 -> Backtrace: 0x400014fd:0x3ffb1ce0 0x400da8f8:0x3ffb1cf0 0x400da91f:0x3ffb1d10 0x400d910a:0x3ffb1d30 0x40149b3e:0x3ffb1d90 0x400d60c7:0x3ffb1db0 0x400d617d:0x3ffb1dd0 0x400d61f2:0x3ffb1e00 0x400d635b:0x3ffb1e50 0x400d9c6a:0x3ffb1ea0 0x400d125a:0x3ffb1ee0 0x400dbd4d:0x3ffb1fb0 0x4008aff9:0x3ffb1fd0
13:11:52.618 ->
13:11:52.618 -> Rebooting...
13:11:52.618 -> ets Jun  8 2016 00:22:57
13:11:52.618 ->
13:11:52.618 -> rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
13:11:52.618 -> configsip: 0, SPIWP:0xee
13:11:52.618 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
13:11:52.618 -> mode:DIO, clock div:1
13:11:52.618 -> load:0x3fff0018,len:4
13:11:52.618 -> load:0x3fff001c,len:1216
13:11:52.618 -> ho 0 tail 12 room 4
13:11:52.618 -> load:0x40078000,len:9720
13:11:52.618 -> load:0x40080400,len:6352
13:11:52.618 -> entry 0x400806b8
13:11:52.919 ->
13:11:52.919 ->  Starting
na mobilu je ten přístupový bod OnDemandAP
mám ale jakmile se toho dotknu tak sice má to snachu něco podobného se ukázat jak je v příloze na founu ale pak se to vrátí zpátky a ESP32 se resetuje 8O .Někdo může namítnout že je to jen pro ESP8266 ale na youtube jsou návody i s ESP32 díky
markoni
#2 Příspěvek od markoni »
Vyřešeno měl jsem špatnou knihovnu
