Lenovo V560 neberie mi žiadnu wifi kartu prečo ?
Kód: Vybrat vše
Atheros QCA9882 MAC/BB Rev:2 (SREV: 0x043222ff)
Unable to select GPIO access ops due to unsupported chip
Chip does not support EEPROM
OTP access ops: use QCA988x ops
Try to load data from OTP memory
Found OTP stream (begin: 0x0024, raw data len: 0x02f2 (754), type: 1 (calibration data), version: 1)
Found block at 0: comp=3 ref=3 length=746 major=4 minor=9
Restore eeprom 0: block, reference 3, length 746
Restore at 0: spot=6 offset=6 length=6
Restore at 8: spot=16 offset=4 length=2
Restore at 12: spot=30 offset=12 length=1
Restore at 15: spot=41 offset=10 length=1
Restore at 18: spot=65 offset=23 length=1
Restore at 21: spot=168 offset=102 length=1
Restore at 26: spot=461 offset=37 length=23
Restore at 55: spot=1042 offset=48 length=17
Restore at 74: spot=1067 offset=8 length=14
Restore at 90: spot=1089 offset=8 length=14
Restore at 106: spot=1111 offset=8 length=14
Restore at 122: spot=1133 offset=8 length=14
Restore at 138: spot=1155 offset=8 length=14
Restore at 154: spot=1177 offset=8 length=14
Restore at 170: spot=1199 offset=8 length=14
Restore at 186: spot=1221 offset=8 length=3
Restore at 191: spot=1244 offset=20 length=1
Restore at 194: spot=1257 offset=12 length=1
Restore at 197: spot=1271 offset=13 length=1
Restore at 200: spot=1288 offset=16 length=2
Restore at 204: spot=1294 offset=4 length=2
Restore at 208: spot=1300 offset=4 length=2
Restore at 212: spot=1306 offset=4 length=2
Restore at 216: spot=1312 offset=4 length=239
Restore at 457: spot=1576 offset=25 length=2
Restore at 461: spot=1584 offset=6 length=2
Restore at 465: spot=1589 offset=3 length=15
Restore at 482: spot=1621 offset=17 length=1
Restore at 485: spot=1625 offset=3 length=27
Restore at 514: spot=1669 offset=17 length=13
Restore at 529: spot=1685 offset=3 length=15
Restore at 546: spot=1716 offset=16 length=32
Restore at 580: spot=1764 offset=16 length=32
Restore at 614: spot=1812 offset=16 length=32
Restore at 648: spot=1924 offset=80 length=96
Found OTP stream (begin: 0x0319, raw data len: 0x0029 (41), type: 249 (unknown), version: 3)
Found OTP stream (begin: 0x0345, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
Found OTP stream (begin: 0x0350, raw data len: 0x0008 (8), type: 250 (unknown), version: 20)
| EEPROM Base Header |
Length : 0x0844
Checksum : 0x3CB2
EEP Version : 2
Template Version : 3
MacAddress : CC:2D:E0:xx:xx:xx
RegDomain1 : 0x0000
RegDomain2 : 0x0000
Allow 5GHz : 1
Allow 5GHz HT20/HT40 : 1/1
Allow 5GHz VHT20/VHT40/VHT80 : 1/1/1
Allow 2GHz : 0
Allow 2GHz HT20/HT40 : 0/0
Allow 2GHz VHT20/VHT40 : 0/0
Cal Bin Ver : 0x0000
TX Mask : 0x03
RX Mask : 0x03
Tx Gain : 0
Rx Gain : 0
Power Table Offset : 0
CCK/OFDM Pwr Delta, dB : 0
40/20 Pwr Delta, dB : 0
80/20 Pwr Delta, dB : 0
Customer Data in hex:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................|
00 00 00 00 |.... |
| EEPROM Modal Header |
5G
Antenna Ctrl Chain 0 : 0x10
Antenna Ctrl Chain 1 : 0x10
Antenna Ctrl Chain 2 : 0x10
Antenna Ctrl Common : 0x220
Antenna Ctrl Common2 : 0x11111
Antenna Gain : 1
NF Thresh : 0
| EEPROM Power Info |
[5 GHz OFDM per-rate target power]
Freq, MHz: 5240 5260 5320 5500 5600 5745
6-24 mbps, dBm: 24.0 24.0 24.0 24.0 24.0 24.0
36 mbps, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
48 mbps, dBm: 22.0 22.0 22.0 22.0 22.0 22.0
54 mbps, dBm: 20.0 21.0 21.0 21.0 21.0 21.0
[5 GHz HT20/VHT20 per-rate target power]
HT MCS VHT MCS | Freq, MHz: 5240 5260 5320 5500 5600 5745
0 0, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
1-2 1-2, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
3-4 3-4, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
5 5, dBm: 21.0 21.0 21.0 21.0 21.0 21.0
6 6, dBm: 20.0 21.0 21.0 21.0 21.0 21.0
7 7, dBm: 19.0 20.0 20.0 20.0 20.0 20.0
8, dBm: 17.0 18.0 18.0 18.0 18.0 18.0
9, dBm: 15.0 16.0 16.0 16.0 16.0 16.0
8 10, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
9-10 11-12, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
11-12 13-14, dBm: 23.0 23.0 23.0 23.0 23.0 23.0
13 15, dBm: 21.0 21.0 21.0 21.0 21.0 21.0
14 16, dBm: 21.0 21.0 21.0 21.0 21.0 21.0
15 17, dBm: 19.0 20.0 20.0 20.0 20.0 20.0
18, dBm: 17.0 18.0 18.0 18.0 18.0 18.0
19, dBm: 15.0 16.0 16.0 16.0 16.0 16.0
[5 GHz HT40/VHT40 per-rate target power]
[5 GHz VHT80 per-rate target power]
[5 GHz CTL data]
FCC 5GHz OFDM:
Edges, MHz: 5180 [5260 5280 5500 5700] [5720 5745 5825]
MaxTxPower, dBm: 30.0 30.0 30.0 30.0 30.0 30.0 30.0 30.0
FCC 5GHz HT20:
FCC 5GHz HT40:
Edges, MHz: 5190 [5270 5310] 5510 [5670 5710] [5755 5795]
FCC 5GHz VHT20:
Edges, MHz: [5210 5290] [5530 5610] [5690 5775]
MKK 5GHz OFDM:
Edges, MHz: 5180 [5240 5260 5320] [5500 5520 5680] [5700
MKK 5GHz HT20:
MKK 5GHz HT40:
Edges, MHz: [5190 5230] [5270 5310] [5510 5550 5630] [5670
MKK 5GHz VHT20:
ETSI 5GHz OFDM:
ETSI 5GHz HT20:
ETSI 5GHz HT40:
ETSI 5GHz VHT20:
