Oprava mrtveho HDD WD2500AAJS
U me neprekvapive prohozeni tech 2 desek na 2TB discich vedlo k tomu, ze nefunguje ani jeden, normalne se roztoci a identifikujou, nijak necvakaj, ale linux hlasi nake serious erory, ze jako z nej nejde cist. Tu flashku sem zkusil pridat do sveho SPIPGM, tak to du zkusit sfouknout a precist. BTW ta moje je na 1.8V, level konverter uz sem si delal driv.
Kód: Vybrat vše
smartctl 6.6 2017-11-05 r4594 [i686-linux-5.7.0-0.bpo.2-686] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Blue Serial ATA
Device Model: WDC WD2500AAJS-75M0A0
Serial Number: WD-xxxxxxxxxxxx
LU WWN Device Id: 0 000000 000000000
Firmware Version: 05.04E05
User Capacity: 250,000,000,000 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.5, 3.0 Gb/s
Local Time is: Sun Jan 3 12:05:55 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 5460) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 67) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 136 136 021 Pre-fail Always - 4166
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 84
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 041 041 000 Old_age Always - 43143
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 82
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 60
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 84
194 Temperature_Celsius 0x0022 108 084 000 Old_age Always - 35
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
240 Head_Flying_Hours 0x0032 045 045 000 Old_age Always - 40738
241 Total_LBAs_Written 0x0032 200 200 000 Old_age Always - 2415638862
242 Total_LBAs_Read 0x0032 200 200 000 Old_age Always - 53973283
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.Nechapem, co mu vlastne stalo. Moduly v ROM aj v servisnej oblasti mali spravny checksum (aj ked obsah dvoch spominanych bol rozdielny) - takze nemohlo ist o nahodne poskodenie.
Podozrive je, ze povodny ROM modul 0D obsahoval nazov disku a verziu firmware 02.03E02. V cinskej ROM ani v module zo servisnej oblasti nazov ani verzia FW nie je. Teraz to ukazuje FW 05.04E05.
Po naflashovani spravnej ROM s nimi disk funguje, takze sa daju pouzit ako nahrada dosky 2060-771590-001 REV A s 88i8846E a externou flash.
Postup: samotnu dosku zapojit na SATA a napajanie, pockat niekolko minut, kym vzda pokusy o inicializaciu (zmizne BSY flag) a nasledne zapisat programom WD Marvel.
A na Seagate disky by naky tooly nebyly?
Z tech 2TB disku sem vydumpoval flashe (1MB) a porovnal, je tam celkem 54525 diferenci ruzne rozesetych v oblastech 30008-3FFFF, 7002E-7F209, ACE02-FFFC0, na konci ma jedna pamet blok FF zatim co druha tam ma naka data, takze to nevypada na par kalibracnich dat, mozna se tam ukladaji cele SMART logy...?
Citelnych retezcu v tom moc neni, asi nejzajimavejsi:
Kód: Vybrat vše
Polar 8051 Calibration timed out; drive will hang
Wait for Polar 8051 idle timed out; drive will hang
Polar 8051 Calibration Failed, controls =
SMI Init (or) Training Failed
a tip disku
ST2000DM001-1ER164 ST2000DM001
Podporu tech 1,8V SPI pameti on On Semi a jeste par dalsich od Winbondu sem pridal do nove verze SPIPGM 2.31
http://rayer.g6.cz/programm/programm.htm#SPIPGM
Ale mam tu jiny problem, nenadale mi prestal fungovat jiny disk Seagate 200GB SATA ST3200826AS, ktery se uplne prestal detekovat. Jeste pred tydnem sem na nej instaloval Win na naky SW, dival sem se na SMART a zadne relocated ani pending sektory nemel. Ted sem ho znovu vytah, pripojil, primo SATA kabelem k desce a nic, zadna detekce. Disk se roztoci a je slyset, ze kazdych cca 8s kratce tukne hlavou. Zkousel sem ho dat do mrazaku, ale nepomohlo. Na te elektronice je taky naka fleska SST25VF. Si rikam, ze kdyz je typ disku, ktery se vypisuje pri detekci, ulozeny v ni, tak by to mohl bejt taky nakej problem s fleskou, ze se jebl naky bit a vubec nenastartuje FW. Zkusim ji vycitat pri ruznych napetich, jesi teda se neceho doberu...
EDIT:
aha maji to i volne
http://files.hddguru.com/download/Software/Seagate/
a tady este neco od rusaku
https://www.phantom.sannata.org/viewtop ... &start=616
Pomocou self-scanu v STComTools som rozchodil par diskov vhodnych predtym akurat na vyhodenie. Na niektorych to skoncilo s chybou - tie som rozobral a vyhodil. Myslim, ze podobny postup pouziva Seagate aj pri reklamaciach...co prejde, oznacia ako "Certified Refurbished".
rnbw píše:Pomocou self-scanu v STComTools som rozchodil par diskov vhodnych predtym akurat na vyhodenie. Na niektorych to skoncilo s chybou - tie som rozobral a vyhodil. Myslim, ze podobny postup pouziva Seagate aj pri reklamaciach...co prejde, oznacia ako "Certified Refurbished".
Zkusil sem precist tu SPI flash SST25VF512 (64kB) a az do 1.7V davala konzistentni obsah, pro jistotu sem ji este smazal a znova zapsal, ale zadna zmena.
Ted sem se pripojil seriovym kabelem, chytlo se to na 9600bd, 3,3V.
Kód: Vybrat vše
4096k x 16 buffer detected
TONKA - 1_Disk M-27 03-30-05 11:42
Head Mask FFFF - Switch to full int.
Spin Ready
3.03 06-21-05 17:16
Zkoustim ST Repair Tool 2013-5-10 ktery ma nejmin cinskych tlacitek, tuknul sem na "Start SF", ted to ruzne hrabe a toci motorem, nemam to zrovna pripojene SATA kabelem, tak mi to zaclo hazet "SATA interrupt nor processed!"
Kód: Vybrat vše
T>((AutoRd Err 43 at ffffffff.01.0003
AutoRd Err 43 at ffffffff.01.0000
INVALID Cert Disk Code - ROM Resident Revision Required: 3.03Jinak v tom STComToolu nejak nefungovalo zadny ukladani ani nahravani pameti ci stop, nejak to rozjebalo UART, vypsalo naky rozsypany caje a zanechalo terminal ve stavu ze neprijimal/nevysilal zadne znaky, bylo treba to pozavirat (nekdy natvrdo sestrelit proces) a odevrit znova. zrejme se to nak snazilo prepnout na vyssi baudy ale nepovedlo se.
Jenze pozdeji jsem zistil, ze jsou s nim problemy i pri pripojeni na onboard SATA radic. SSD sem kompletne vymazal pres ATA Secure Erase (utilitou vyrobce ADATA SSD Toolbox), cimz se behem par s vsechny sektory vynulovaly. V tomto stavu se SSD chovalo OK, pri cteni dosahoval vysoke rychlosti a pri cteni vsech sektoru nebyla zadna chyba. Jenze jakmile sem SSD rozdelil a nahral na nej OS a dalsi programy, tak nastaly problemy. Kdykoliv jsem zacal vice cist nez jen sem tam jednotlivy soubor, tak se SSD zaseknul, HDD LED zustala trvale svitit a uz jsem z nej nic neprecet. Az po tvrdem resetu zas nabehl a mohl sem neco malo precist. SSD obsahuje legendarni srackoradic SandForce 2281 (ktery provadi runtime kompresi dat), tak jsem zkusil aktualizovat FW z 5.0.2 na posledni 5.8.2, vymazal ho a znovu nahral data - zapis byl bez problemu, ale nasledne cteni opet s dlouhatanskymi timeouty, takze novy FW ani full erase to neresi. SSD proste postupne presel do faze WOM (write-only memory
Jako posledni moznost by se dala vyzkouset tovarni reinicializace leaknutym softwarem Genesis primo od vyrobce prepnutim do recovery rezimu pomoci jumperu, ale ten postup je docela komplikovany, vyzaduje instalaci urcite verzi Fedory v kere ten SW bezi... ale spis myslim, ze to uz bude proste naka degradace tech flash cipu, ze by to stejne nikam nevedlo....
