Proto si myslím, že nejkratší cestou je čistá instalace nového OS Windows. Odkazy na stažení iso jsem ti dal. Za dvě hodinky není co řešit a můžeš se věnovat činnostem, které tě baví.
Kde môže prebývať malware v PC ,aj po preinštale Win 10?
- tiktak1953
Urobím hodinársky kurz pre začiatočníkov podľa priania.
Takže odporúčam vymeniť router, či bude tvoj problém pretrvávať.
- tiktak1953
The ipconfig /all command displays detailed network configuration information for all network adapters on a Windows computer, including IP addresses, DNS servers, MAC addresses, DHCP status, and more.
Overview
The ipconfig /all command is an extended version of the basic ipconfig command in Windows. While ipconfig shows only basic IP address information, adding /all provides a comprehensive view of every network adapter, including physical, virtual, and sometimes inactive interfaces
techbloat.com
techbloat.com
+1
. This command is essential for diagnosing network issues, verifying network settings, and confirming which adapter is active.
Key Information Displayed
When you run ipconfig /all, the output includes:
Adapter Name and Description: Identifies each network interface and its hardware type
Windows Report
Windows Report
Physical Address (MAC Address): Unique identifier for the network adapter, used for device identification and router access rules
techbloat.com
techbloat.com
+1
DHCP Enabled: Indicates whether the IP address is assigned automatically via DHCP or manually configured
networkproguide.com
networkproguide.com
IPv4 and IPv6 Addresses: Shows the assigned IP addresses for each adapter
techbloat.com
techbloat.com
+1
Subnet Mask: Defines the network portion of the IP address
networkproguide.com
networkproguide.com
Default Gateway: The router IP used for o
Otevře se okénko s řádkem Otevřít, do kterého napiš: cmd
Otevře se okno Příkazový řádek, do něhož napiš ten příkaz: ipconfig /all
(nezapomeň na tu mezeru)
edit: alebo ako radí masar, je to skoro to isté. (písali sme naraz) Dá sa použiť aj -all aj /all, je to to isté.
- tiktak1953
Microsoft Windows [Version 10.0.19045.2006]
(c) Microsoft Corporation. Všetky práva vyhradené.
C:\Users\gogo>ipconfig
Windows IP Configuration
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::b53d
IPv4 Address. . . . . . . . . . . : 192.168.0.103
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
C:\Users\gogo>
- tiktak1953
Útočníci na webe, na ktorý ste sa pokúsili prejsť, sa vás môžu pokúsiť podvodom presvedčiť, aby ste si nainštalovali softvér alebo prezradili informácie, ako sú vaše heslá, telefónne čísla či čísla kreditných kariet. Chrome dôrazne odporúča, aby ste sa vrátili do bezpečia. Ďalšie informácie o tomto upozornení
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-31-DC-50-E4-F0-4D-A2-36-6D-68
DNS Servers . . . . . . . . . . . : 79.137.248.105
89.208.105.113
NetBIOS over Tcpip. . . . . . . . : Enabled
- tiktak1953
IP adresa 79.137.248.105 je známý škodlivý (malicious) DNS server. Pokud jste tuto adresu našli v nastavení svého routeru nebo počítače, znamená to, že vaše zařízení bylo hacknuto pomocí útoku DNS Hijacking.
Útočníci zneužívají bezpečnostní chyby v routerech (často značek Actiontec, TP-Link či starších SonicWall), vzdáleně v nich změní DNS servery na své vlastní a přesměrovávají internetový provoz na podvodné a ruské malware stránky.
Okamžité kroky k nápravě
Pro zajištění bezpečnosti vaší sítě proveďte co nejdříve následující kroky:
Změňte DNS v routeru: Přihlaste se do administrace routeru a ručně změňte servery DNS na bezpečné veřejné poskytovatele:
Cloudflare: 1.1.1.1 a 1.0.0.1
Google: 8.8.8.8 a 8.8.4.4
Quad9 (zvýšená bezpečnost): 9.9.9.9
Aktualizujte firmware: Nainstalujte nejnovější dostupný firmware pro váš router. Výrobci v nich opravují zranitelnosti, které tento útok umožnily.
Změňte přístupová hesla: Změňte administrátorské heslo do routeru i heslo k Wi-Fi síti.
Vypněte vzdálenou správu: V nastavení routeru zkontrolujte a vypněte možnost správy z zvenčí (Remote Management / WAN Management) a zakažte UPnP, pokud ho nevyžadujete.Kontrola zařízení: Proskenujte počítače a telefony v síti antivirovým programem.
Na zařízeních ignorujte a neodsouhlasujte žádné podezřelé výzvy k instalaci bezpečnostních certifikátů.
