Sháním výrobu Lightning Activated Trigger Ir
(1) Arduino Nano http://www.ebay.com/sch/i.html?_from=R4 ... Categories
(1) photo transistor http://cz.mouser.com/Search/ProductDeta ... a8z01VKy8=
(1) Infrared LED http://cz.mouser.com/Search/ProductDeta ... a8z01VKy8=
(1) 9V Battery Connector – source – Also a 9V Battery for power when not connected to USB cable http://www.radioshack.com/product/index ... Id=2062219
(1) Blank Circuit Board for Input and Output Connections (Cut to size needed) – http://www.radioshack.com/product/index ... Id=2104052
(1) On/Off Switch http://www.radioshack.com/product/index ... Id=2062490
(2) Push Buttons http://cz.mouser.com/Search/ProductDeta ... 12-TL1105B
(1) Project Box
(X) 47 Ohm Resistors http://www.radioshack.com/product/index ... Id=2062347
(X) 10k Ohm Resistors http://www.radioshack.com/product/index ... Id=2062347
(X) 100k Ohm Resistors http://www.radioshack.com/product/index ... Id=2062350
mám aj návod v Aj odkazy na nastavení apod (přeložím ) kdyžtak napište na atria18@seznam.cz
dikes
imgp7444.jpg- (63.74 KiB) Staženo 189 x
imgp7450.jpg- (193.89 KiB) Staženo 197 x
imgp7397.png- (261.7 KiB) Staženo 205 x
